I am missing the power steering adjustment bracket for my daughter's truck. The mounting bracket is on the pump, but the bracket that mounts to the engine and allows you to tighten the belt is not there. I have found one on Ebay, but it is for a 351/400. I know it will fit the bracket on the pump side, but am unsure about mounting to the 300. Does anyone know if they are the same?
No, it won't bolt up. The part you're looking for is either C7AZ-3A732-A, this is for trucks below s/n O80,001 or D7TZ-3A732-B for trucks from s/n O80,001,
One of my parts locators is down right now. When it comes back on line I'll see if there are any new ones available.
Here's the illustration from the Ford parts catalog. It's not real clear or detailed but the 6 cyl is at the lower left.
Click on the .pdf link to view.
I think that is it! Thank you! I bought it. I had just gotten back from a junk yard, with no luck. Although, I think I will go back and get some doors I found and maybe the stepside tailgate. I don't really need the tailgate, but it is in better shape than my daughter's, and will be a good spare.
