1999 f-250 cummins and nv4500 swap
I have a 1999 ford f-250 4x4 ext. cab. It is a 5.4 auto, switch operated transfer case. Im going to install a 98 12v cummins, a rebuilt nv4500,and dodge manual transfer case. Im in need of info and parts. In need of clutch pedal assembley, intercooler, and things to change things for manual t-case( boots , floor pieces). thanks for any info
send me your email
this is my build 98 12v 4500 273 t case now a manual shift the way I look at it if you are going to spend 700-1500 on adapter plates why not put that money in a really good clutch
4500 is a good trans just have to fix the fifth gear issue here is a fix that really works
http://fifthgearrepair.com/<wbr>nv4500repair.html
you will be better off with the 273 than the 241 hd or dhd the second number is t case strength the higher the number the stronger
here are some pics of my build
http://s1125.photobucket.com/<wbr>albums/l582/deck60/ford%<wbr>20cummins/
ss27gogeta
18
06-25-2014 12:44 PM
cadunkle
03-02-2006 09:30 PM
