1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Need some answers on F-350 Dually rear brakes quick.
Old 04-01-2012, 09:30 AM
fabiodriven's Avatar
fabiodriven
fabiodriven is offline
Hello all!
First of all, the truck we're dealing with- 99 F-350, 2wd, 6-speed, 4 door, 7.3
I had my rear wheels off yesterday to to a wheel rotation and re-paint. It was the first time I had them off the truck since I bought it a year and a couple months ago.
First of all, my parking brake sucks and has since I bought the truck. It's iffy at best and I usually have to park the truck in gear. I've been meaning to address it for some time.
Secondly, I knew my rear brakes were worn and I could tell the fronts were doing a lot more of the work than they should be. I was appalled to see how bad my rear brakes really are. Plenty of meat on the pads, but rotors are smoked.
I just ordered a brand new set of rear rotors and pads, but I'm not sure what to order for the parking brake. I've never had it apart so I don't know how many shoes I need to order. Are these the type with one big "horseshoe" shoe, for a total of two shoes? One on each side? Or is it two shoes each side, like a traditional drum brake setup?
The rotors that are on the truck look like they're going to fight me a bit. Do I need a press to get them on/off?
Should I get new axle seals or is there anything else I should get that I don't already know about?
Sorry for the rush and the barrage of questions, but when I pull it apart it has to get done and go back together ASAP as this is my only non-two wheeled mode of transportation.
Thanks for looking guys!
Old 04-01-2012, 10:22 AM
powerstroker100's Avatar
powerstroker100
powerstroker100 is offline
Your going to need to remove the hub, so you'll need the special spanner socket for that, the shoes are a 2 piece design, there is a really good writeup on here of a guy with a v10 I believe and he does the backing plate and new shoe install, try to search for that it has good pictures
Old 04-01-2012, 10:28 AM
fabiodriven
Most of those spanner nuts I usually just use a chisel on. Is there any reason I can't do that in this case?
Old 04-01-2012, 09:19 PM
fabiodriven
I just had somebody else tell me I do not need to remove the hub. Do I have to remove the hub or not?
Old 04-02-2012, 09:06 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Is this a dually? If it is, you need to pull the axles to get the rotors off.
Old 04-02-2012, 09:08 AM
fabiodriven
It is a dually. You are right, the hubs do need to come off. Thanks man.
coolbrze
03-14-2019 02:44 PM
Ducter
04-27-2017 04:05 PM
SGorman13
05-22-2012 09:42 AM
HomeSolutions
11-22-2007 02:05 PM
mbunney
10-29-2003 09:33 PM
Quick Reply: Need some answers on F-350 Dually rear brakes quick.
