External vs internal regulator
If I wanted to change out an externally regulated AC alternator for an internally regulated one what changes if any would have to be done to the wiring? Just unplugging the harness to the current external regulator would be too simple and nothing seems to be simple these days
Here's a pic of what needs to be removed:
https://www.ford-trucks.com/forums/p...ictureid=10932
Read through this thread: https://www.ford-trucks.com/forums/9...g-upgrade.html
FYI: FE owners with hi-mount alternators
If your 3G is off a Taurus, Contour, or Windstar, the aluminum boss/ear on the rear case will need to be removed with a hacksaw because the boss will create interference against the passenger side cylinder head.
3Gs from Mustangs, Cougars, and T-birds do not have the boss.
Are you talking about the pink resistor wire? If you are there is a brown wire that comes off it by the firer wall connection the goes to the start relay. This a by pass wire to give the coil full voltage for starting. Using a different wire than the pink resistor will evenually burn out the coil. Are you getting voltage to the coil with ignition turned off?
haven't checked that out but will see
There were two different resistor wires used 1971/72, not one, as it depended on the applications.
COLF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37).
61.49" long / Color coded Pink / 1.30-1.40 ohms resistance / #20 gauge Wire / All 1960/70 FoMoCo vehicles, some 1971/72's.
D1AZ-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-84-A).
60" long / Color coded RED w/GREEN stripes / 1.30-1.40 ohms resistance / #16 gauge Wire / Some 1971/72 and all 1973/76 FoMoCo vehicles.
Cbad285
07-05-2015 10:44 PM
Xenthrax
16
01-27-2014 08:15 PM
c_silva88
01-26-2013 10:09 AM
59Fguy
05-23-2004 08:40 AM
