3G Swap: Should I think about doing one?
#94
Thanks
I've been asked about it a few times, so I wanted to have good info to give out. I went to my favorite JY Fri. and I found one ... just wanted to confirm it.
I picked up a set of 98 Windstar E-fans they are a nice tight fit on my radiator ... I want to get the conversion going next week our 100* days willl be here soon !!!
My 6 Liter tune up netted me m14.47 MPG for 166+ miles over a 5,000 high mountain on a 90* A/C on for 3 hrs. mid day ... can't wait for the fans and headers YES !!! Dave
#96
Here's a shot of my current alternator...
The two bolts currently fastening the existing 2G are marked with a red dot and they are about 6" apart. For the 3G, I'm thinking I would use the same upper mount, but the lower would be the one to the left and down a bit of the existing one - they seem to be about 7" apart, which would be the correct dimension for the "smaller" 3G.
Using those mounting locations would pull the alternator in closer to the engine - am I going to have any clearance issues as a result?
Any insight appreciated.
#97
Yes you will reuse the bottom bolt and the top bolt will also be reused in that hole on to next to the other bracket bolt. If you get it from the right donor vehicle you shouldn't even have to swap pullies. The top bolt hole will be a cleaner fit if you drill out the top hole in the donor alternator and tap it to 3/8-16 thread.
#98
1) Both bolts get re-used
2) Lower bolt-holes get re-used
3) Upper mounting location changes to more outbound one - the currently un-used one out at the end of the bracket. If that's the case, I'll need the 8.25" 3G alternator.
#99
#100
Great picture, thanks. And yes, confirmed, 8.25" 3G required. Of course, I've got two 7" 3G's on the shelf.
#101
You lost me there a bit. I think what you are saying is this - I'll itemize for clarity...
You got it
#102
Just to follow-up on this thread with some info specific to the 4.9. For the final two years, '95 & '96, the 4.9 in the F150 finally got a 3G from the factory, but NOT the one "everyone" suggests as a retrofit - the one with the mounts 180 degrees across from each other, 8" apart (as used on the 3.8 Taurus and others).
The one used by the factory mounts the same as the 2G, with the ears about 120 degrees apart. It's Ford part# F2UU-10300-EA, and is also used on the '92 - '96 E-series Van. Here's a pic...
From what I've read, this one ^^^ may put the wiring in a more accessible location than the Taurus alternator, so it may be a slightly "better" option. I suspect the Taurus alternator has been more frequently recommended simply because it has better availability in the junkyard.
One final note before you head out to the junkyard in search of this alternator.... Bolt-head size is 1/2" for the upper and 9/16" for the lower. This engine sure is a jumbled-up mess of Metric and English fasteners.
Some additional info.... The above pictured alternator is 95 Amp and often referenced in the after-market as Lester 7755. The 8" "Taurus" alternator is 130 Amp and referenced as Lester 7756. So if you're looking for some greater amperage output, the 8" one might be what you want after all.
The following 2 users liked this post by DPDISXR4Ti:
#103
Mind you, it wouldn't surprise me if I snapped the bolt standing on my breaker bar. Indeed at that point the alternator would go to the grave attached to the engine.
#104
Alternator Parts
I have a 87 F150 5.0L E4OD 2WD XLT Lariat single cab.
There are several 3G Alternators at the boneyard already pulled and on a shelve. Preferably, I want at least 120 Amp.
My questions are: Where do I purchase the necessary wiring, mega fuse, etcetera?
Is there any information on the alternator designating amperage and perhaps the year.
Please advise and thank you.
Boon
#105
Hello and good morning SCRebel.
Boon
Boon
Also here is info on the 3g interchange
3G Interchange Facts. If you're thinking 3G read here. - FSB Forums
