56 F100 restoration - Page 4 - Ford Truck Enthusiasts Forums
56 F100 restoration
  #46
Old 05-13-2012, 01:15 AM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Quote:
Originally Posted by AXracer View Post
I've changed a lot of late model shocks, and can't remember one where the suspension hung from the shocks. If that was the case you would slam the pistons and/or valves into the upper end of the shock when the suspension drops, damaging it for sure. The rear wheels leave the ground more often than just doing a DOH jump. Some shocks are gas charged with a chamber or bag filled with nitrogen in the upper part of the shock. I'd be really upset if the suspension ever allowed the piston to hit the extended limits of my 3500.00 racing shocks!
I guess I speak mostly of 80s and older stuff. In my mind 'late model' is 1980 and newer... Everything I own and/or work on most of the time is 1980 and older. And certainly... if $3500 shocks did that, I'd certainly be upset! Was more referring to your over the counter Monroes, Gabriels, and whatnot. I know on the older stuff, once you disconnect the shock at any corner while its up on the lift, you gain a little more drop from the suspension... usually aids in spring removals or other suspension work.
  #47
Old 05-17-2012, 12:23 PM
South of BC's Avatar
South of BC South of BC is offline
South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.
This week is short because Mark is going to the 'Lost in the Fifties' show in Sandpoint, ID. He is taking a '48 Ford he built for a client. Needless to say, mine isn't ready! I was absent from the shop this week, I went to a farm auction Saturday and won, among other things, about six cords of firewood that I had to move. I showed up yesterday afternoon dead tired, but Mark had put the engine back in. We had it in last week but had to pull it out because the flywheel bolts from the standard tranny were too long for the flexplate of the Fordomatic. Which hasn't been the only headache, I didn't have the bell crank, linkage, or dashpot, and the throttle assembly had been butchered by my dad. The guy I bought the tranny from sent me a bell crank (which proved to be the wrong one) and a couple of throttle assemblies, one of which is workable. Mark found a NOS bell crank on eBay, so now all I need to come up with is the dashpot. However, that isn't the end of the tranny woes, the drive shaft I got with the tranny is the wrong one, it's too long. So Mark is going to drop it off in Spokane next week on his way to the airport on his way to Lost Wages for the week. So next week will be catching up on farm chores and getting the bed wood finished and painting the fuel tank.
  #48
Old 05-17-2012, 12:47 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
That Y Block is a beautiful thing to behold.
  #49
Old 05-18-2012, 06:26 PM
Dano78's Avatar
That is sure lookin purrrrr-dy!
  #50
Old 05-19-2012, 09:40 PM
abe's Avatar
abe abe is offline
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Glad to see you painted the trans cover and the battery cover black as they were originally...
Very nice looking truck so far, engine looking good!
  #51
Old 06-01-2012, 08:51 AM
Not much happened the past couple of weeks, and then the project took an unfortunate turn. The guy working on my truck went on vacation and my wife went to San Diego. Mark got back and fixed the carburetor linkage. The kick down rod was too short and the shift rod was too long. He welded a length to the kick down rod, but hadn't cut the shift rod yet. Meanwhile the wife was getting frustrated with the amount of time and money the project was taking. I had originally told her I thought it would be around $20K. When it approached 30 she said that was the limit. Well, it's now at 40 and she said I had to finish it myself. I was able to negotiate (we have a sort of Higgins/Magnum relationship) that I would finish the bed and interior. When we sell a piece of land near Sandpoint, ID (anyone interested in seven acres with a semi-private dock on the Pend Oreille river?) she'll let me take the truck back to the shop to get the drive train finished. With the real estate market being what it is, I'm not holding much hope of selling the land soon. So I'm banking on our rentals. We have two units that have been empty for about six months now. They need a little work which I've put off to work on the truck. If I get those done and occupied I'll be in good graces. I was hoping to have the truck done this spring so I could be taking my dad for drives this year. Hopefully I can pull it off before autumn so I can take him for drives before the snow falls. His mental condition is worsening, but he's strong and healthy physically. (BTW, thanks for asking arctic y block)
Yesterday I brought the truck home. We put in the drive shaft, set the bed on, finished the brakes and bled them (one fitting at the stop lamp switch leaks and will have to be replaced) and put on the wheels. Of course it didn't rain all day, just when I was driving home, and quit once I was here. I took a few pictures and then put it in the shop. I'm hoping to not have to take it off the trailer until it's finished, it needs to go to Spokane to have the windscreen installed and back to Mark to finish the motor. After getting it in I checked the cab corners for water. One of them had about an inch of sand still in it that was now wet, so first order of business will be to get that out and dried. After that I'll empty out an enclosed trailer I have and organise all my parts in it. Then, with some friendly advice here, and between farming and rental work, I'll be tackling the bed and interior.
One final note, when I drove in my wife had my dad pulling up some grass to feed to the pigs. I pulled up alongside him and pointed to the back and said I found some piece of junk on the side of the road. He looked and said, "I know that truck" and then told me how glad he was I was taking care of it and keeping it going.
  #52
Old 06-01-2012, 02:19 PM
Dano78's Avatar
Awesome! That thing is lookin SHARP! I like how you presented it to your dad... I think their replies are worth more than any amount of money you could put into these trucks. You know darn well he's probably tickled to death you're fixing up his old truck.
  #53
Old 06-01-2012, 10:47 PM
tiltbilt tiltbilt is offline
tiltbilt is starting off with a positive reputation.
Very cool what your Dad said when he saw it !
  #54
Old 06-02-2012, 06:27 PM
tempforce's Avatar
tempforce tempforce is offline
tempforce is starting off with a positive reputation.
great story and thanks for posting all of the photo's.
hope things work out, so that you will be driving your father around in his old truck. i think he will enjoy you having it all fixed up and the truck being used again.
  #55
Old 01-01-2013, 06:18 PM
Project-55's Avatar
Project-55 Project-55 is offline
Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.
James, so what have you been up to on the truck recently? I Finally got my IRS all overhauled and painted which is the only good looking piece on my truck, as you know.
Gary
  #56
Old 06-14-2014, 03:37 PM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
Very inspiring to se a stock yellow motor restoration. I am planing same route but with a modern 4 barrel and Easton ps pump, stock chassie red body, black rims.
Love your thread, waiting for the rest.
  #57
Old 06-15-2014, 03:56 PM
The only thing I see that I would change is to a duel rams horn exhaust.
I don't think it would take any away from its originality. And the benefit
of better sound, more power and burn less fuel is a plus. I am not sure
if it was an option on the small trucks but was on the bigger ones.
Just thinking out loud Bud. Your truck is really a work of art. I hope yer
building her to drive and not trailer everywhere.
  #58
Old 12-03-2014, 06:11 PM
ford_pickup ford_pickup is offline
ford_pickup is starting off with a positive reputation.
Beautiful Truck, what ever happened
  #59
Old 12-03-2014, 11:36 PM
willymakeit willymakeit is offline
willymakeit is starting off with a positive reputation.
Great truck and story to go with it.
  #60
Old 12-04-2014, 09:06 AM
I just love this truck. I have saved these images and looked at them once and a while for inspiration. Itīs a tru beauty!!!
But I have a question?
Your front springs, are you sure they are supposed to be mounted that direction ? with the extra loop on the second leaf pointing forward?
On my thruck they where pointing backwards, it seems like they are original springs with the partnumber stamped in instead of painted and the wear and tear on the rear framebrackets indicates they have been mounted like that for a long time.
But I am not 100% sure.
Anybody that knows??
Let me tell you a story... FoxFord33 Ranger & B-Series 2 01-22-2017 12:58 AM
Pay off ford credit loan,lose rebate? jyarosz 2009 - 2014 F150 19 03-08-2016 04:51 PM
How's this for a bus? gangstakr 1961 - 1966 F-100 & Larger F-Series Trucks 7 07-18-2013 12:27 AM
Rocks and Dynamite smokestone52 General Automotive Discussion 7 03-06-2007 12:06 AM
Time to grow up. f15terwitha6ter General NON-Automotive Conversation 22 03-28-2005 09:40 AM
Tags
56, 56f100, f100, fit, ford, general, hospital, images, kennewick, piece, powered, restoration, sheetmetal, truck, vbulletin, wa, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
