Fifth wheel and motorcyle carrier - Ford Truck Enthusiasts Forums
Old 04-01-2012, 12:17 AM
cirrus365's Avatar
cirrus365 cirrus365 is offline
cirrus365 is gaining momentum as a positive member of FTE.
Does anyone have any experience adding a motorcycle carrier to the back of 5th wheel trailer?? More specifically I want to add one to haul my dirtbike but don't want to move to a toy hauler.
Old 04-01-2012, 10:11 AM
onug's Avatar
onug onug is offline
onug is gaining momentum as a positive member of FTE.onug is gaining momentum as a positive member of FTE.
I recommend talking to a frw weld shops and seeing what they can do. I just added a receiver to my trailer to haul bicycles. The biggest factors were the trailer's frame size, frame access and the carrying weight.
Old 04-01-2012, 10:20 AM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
Here is what I have seen folks do as it solves a multitude of possible problems including overloading rear axle on fiver The ultimate single wheel trailer system..
Steve
Old 04-01-2012, 12:51 PM
cirrus365's Avatar
Quote:
Steve
That is really cool. Would it be considered double towing?
Old 04-01-2012, 03:01 PM
RV_Tech's Avatar
Quote:
Shouldn't pose a problem. I have talked with a couple of folks who have used them all over the country.
Steve
Old 04-01-2012, 05:05 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
IIRC, federal regs allow for 15' of length behind the centerline of the rear axle without any special permits, but also remember that that platform will swing way out wide on corners. If you go to any tight campgrounds or off the highway in any cities, then you may run into so issues.
Free thread monthly pruning hav24wheel Excursion - King of SUVs 54 03-07-2015 10:41 AM
Spare Tire Carrier Questions FordFETruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 24 01-17-2015 03:16 PM
Differential Carrier removal Radster 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-13-2013 02:44 PM
10.25 rear end carrier bearings / races nomad221 1994.5 - 1997 7.3L Power Stroke Diesel 14 05-29-2012 02:24 AM
cargo carrier for 2" trailer hitches white Buffalo 1999 - 2003 7.3L Power Stroke Diesel 13 09-18-2011 01:34 AM
Tags
back, carrier, carriers, ford, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
