If you do have Cruise Control, it should be mounted up above the steering column behind the instrument panel....by, or even on, the speed control amplifier.
i checked all the fuses they are all good but there is no power going to the wire on the horn button or the horn its self. i ran a wire to the positive post on my battery and it works fine. so is something not hooked up. i changed the turn signal switch a while back maybe i did it wrong
He said he has cruise, so he supposed to have a horn relay, like you said, up behind the dash on the left side of the steering column. Does the cruise control work? There is a chance someone swapped in another steering column with a wheel that had the buttons, but didn't originally have cruise. If that's the case, you might have a problem, I haven't ever looked on how you would handle something like that.
Oh yes he did....I'm sorry for that then...I completely mis-read that!!
Yes...power would then go from the fuse to the relay...if you have it.
I changed the steering wheel that had the buttons. And I took out the cruise control thing that was on the driver side fender under the hood because I wasn't using it anyways
If you changed the steering wheel pad to a non cruise one, they are wired differently. I found that out the hard way when I put a cruise pad in my non cruise truck.
