water separator sensor
Yes it probably just gummed up and needs cleaned out it happens kinda common
Do a search on here I think there was some good writups on it
here is all I have in my stash of threads
HFCM REMOVAL AND DISSASEBLY
https://www.ford-trucks.com/forums/a...6&d=1324481833
It might show some diassembly stuff but its not really what I wanted
Ya it wasnt it theres a diffrent one somewhere
Are you using Motorcraft or Racor fuel filters?
Then it may just need cleaned. You can use brake cleaner and bend the little tube and soak the sensor down through the drain hole. That would be the first thing I would try. If necessary you might have to take the manifold cover off to get in and clean it.
I would still continue to drain it often to make sure you're getting all the water out.
And like I said, make sure you're using OEM filters. Either Motorcraft or Racor.
hdfxrusa
02-09-2012 06:59 AM
