What do Y'all Make of This Ad?
Still looking around at trucks. I've called and emailed the owner of this truck, waiting to hear back from him on what exactly "needs rebuilt" means. I know the 300 is a stout little beast, so I figure it's either something simple like valves, or it's a spun bearing, broken chain, etc. In that case I'd be better off putting in a used 300, right? I'll update when I hear back from him.
88 ford f250
-Dave
88 ford f250
-Dave
I could make a hat...or a broach...a pterodactyl...
<width="480" height="360"><param name="movie" value="http://www.youtube.com/v/em9PtzQzWOg?version=3&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/em9PtzQzWOg?version=3&hl=en_US&rel=0" type="application/x-shockwave-flash" width="480" height="360" allowscriptaccess="always" allowfullscreen="true"></embed>
Hahaha I'd almost forgotten Robert Stack was in that. Good one BVA.
Yep, it came with a 12/20 warranty. The 12mos. is already up.
Truck is a service body with plow hookup up front. Leads me to believe this thing is used hard and infrequently. Owner said put a little oil in the cylinder, turn it over a couple times, and compression goes up. Think I'll pass on this one... haha
If it's no compression on a single cylinder it's either a piston or a valve that is the problem.
Why pass on it? If the truck is decent you can always change the engine.
Check the truck over good and if it checks out you can always throw in a good used engine.
I've bought worse looking vehicles and swapped engines or transmissions.
acarter92
09-12-2013 05:08 AM
Montana Bob
13
04-19-2005 03:51 PM
underDAWG
01-31-2004 08:55 AM
