fuel tank selector valve - Page 2 - Ford Truck Enthusiasts Forums
Old 04-12-2012, 10:09 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Here is a link you can go too for the information:
Fuel Injection Technical Library How To Run a Self-Test
Old 04-12-2012, 03:49 PM
part timing part timing is offline
part timing is starting off with a positive reputation.
Quote:
Originally Posted by klricks View Post
See the link in my signature below for info on how to run the self tests and retrieve codes. I also have a writeup on the dual tank switching system.
Your link is not working.
Old 04-12-2012, 04:14 PM
klricks klricks is offline
klricks is starting off with a positive reputation.
Quote:
Can you give any details or error messages?
Thanks
Old 04-13-2012, 08:14 AM
Internet Explorer cannot display the webpage
Old 07-13-2014, 07:59 PM
elkasdad's Avatar
elkasdad elkasdad is offline
elkasdad is starting off with a positive reputation.
SubFord - I found your fuel tank selector switch thread searching for the wiring diagram for that switch on my 1977 F-250. I also see that you have a 77 F250. Can you help me track down the same sort of diagram for our truck? We are troubleshooting a dead fuel gauge and have tested a bunch of things including ground at the send units, ohms there, pulsing 5v from the IVR, etc, but cant quite figure out the ins and outs on that fuel tank switch and think since the gauge reads dead on both tanks, and all seems to be in order with the send units, it must have something to do with the path through this switch. The switch does work to actuate the actual fuel tank/line switch solenoid. Switching tanks at the switch works, but no reading on the fuel gauge.
Thanks for any help you might offer.
Jeff
Old 07-13-2014, 11:45 PM
subford's Avatar
My 1977 only has one tank and it is in the cab behind the seat.
Here is how it is wired, the diagram is for an 1983 but just looking at the fuel select solenoid that is the same except the fuse is F3. Power on tho the solenoid selects the front tank (mid) and with no power it is the rear tank (aft).:
Old 07-14-2014, 11:49 AM
elkasdad's Avatar
Thank you
Quote:
Thank you for the response and diagram. Do you know where I should look to find the wiring diagram for the tank switching system on the 1977 F250? I have the Haynes, Chilton and set of 5 pdf versions of this thing's manuals but none has this wiring diagram.
Old 07-14-2014, 02:52 PM
elkasdad's Avatar
My bad - Your Diagram Should do the trick
My bad subford > this diagram shows both single and double fuel systems. Note the grey box called"Fuel Tank Selector Switch"...it feeds the gauge from either front or rear tank through the yellow/white wire to connector C208A. That could be the point common to both tanks we're looking for!
Old 08-18-2014, 08:05 PM
epdukes13 epdukes13 is offline
epdukes13 is starting off with a positive reputation.
subford- FUEL TANK SELECTOR VALVE
[quote=subford;11652239]Location as said above is on the drivers side frame rail under the bed:
Fuel tank selector valve:
Hey Subford, where's the best place to buy this fuel tank selector valve, O'rielly's nor AutoZone don't carry them or they carry a electric type.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Can it be cleaned out, having intermittent problems with it selecting the rear tank pump?
Old 08-18-2014, 11:00 PM
subford's Avatar
Most just order them from a Ford dealer but you will need the part number.
Some have cleaned them with limited success.
Part number:
Selector valve assy, p/n F1UZ-9B263-B.
Old 09-07-2014, 07:01 PM
bobajabob bobajabob is offline
bobajabob is starting off with a positive reputation.
Rock auto carries selectors, switches and relays.
Old 01-13-2017, 09:18 AM
Sgtusmc98 Sgtusmc98 is offline
Sgtusmc98 is starting off with a positive reputation.
f350 2002 overhead console/fuel gauge
My over head console stopped working, if I took the cover off it worked so I assumed it was a loose connection, Jammed a gum wrapper in the slot for the readout connection and it fixed the overhead console. Then I noticed the fuel gauge stopped working. Spent some time researching that and dreaded dropping the tank. Today I disconnected the overhead console wires and the fuel gauge started working again.
  #28
Old 01-13-2017, 08:20 PM
Quote:
Sorry! Wrong place and Year!
1986 fuel tank selector valve 6 port OConnorRacing Fuel Injection, Carburetion & Fuel System 1 06-27-2014 04:46 PM
86 fuel tank selector valve ????? OConnorRacing Electrical Systems/Wiring 3 06-19-2014 05:52 PM
86 fuel tank selector valve ????? OConnorRacing 1968-2013 Full Size Vans 2 06-18-2014 10:22 PM
fuel gauge/tank wiring mouse80 1987 - 1996 F150 & Larger F-Series Trucks 0 05-23-2010 09:51 PM
Fuel Tank Selector Valve JCastellaw 1966 - 1977 Early Broncos 7 08-16-2008 09:58 AM
Tags
1972, 1977, diesel, direction, f250, ford, front, fuel, fueltank, selector, switch, switching, tank, tanks, truck, turn, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
