1986 duraspark conversion 300 I6
Hi guys, ive been researching this on this form for years and collecting parts but the project got put on hold for a mini van. (had irish triplets,lol , twin girls then a year later a baby boy) any way i know this has been discussed on here a hundred times and currently i am still searching the forum, but i thought i would ask incase someone had the answer before i found it. the wiring harness i have only has 2 plugs on it. 1 to the distributer and one to the control module. but it looks like someone got to the harness before me and i have 4 open wires. 2 red, one red with a green strip, and a yellow one. all the other connections are there i think. coil, oil pressure ect. can i use this harness or should i just scrap it and try to find a new one? i am researching and looking at pics of diagrams but cant figure out these other 4 wires. there was also 2 purple wires with white stripes but were cut at both ends, didnt go to anything. not sure if those are needed either. thanks guys. any help would be appreciated. im trying to get this done before work on monday and will keep searching the forum also.
after further inspection of the harness, the red and yellow wire go to a plug (oil pressure?) the other red goes to the other connector(water temp?) and the red with green stripe goes to the coil. can i just cut of the plugs that are already in the truck and wire these to them or is it too much trouble and just get another harness? and i dont have or cant find the single green wire withe the plug on it that seems to be in all the pics ive seen.
I can't help you with the other aspects of your problem, but the green wire with the plug is your tachometer connection. If you don't have a tach, you won't miss that plug at all.
I searched and searched but can't seem to find it myself. But awhile back someone posted a wiring diagram for the DSII harness, for people that could not find one, so they could make there own. The plugs were available from NAPA from what I understand.
Maybe someone will jump in that remembers where to find it. Wish I could help more but mine has the TFI setup.
Let me google that for you
Comes back with two pages of results, at least the top half of the first page of results seems to have some stuff that might help here (didn't look at later stuff).
OK, testing before posting this, the display looks to be truncated (but still works as designed).
What I typed at the end was "site:ford-trucks.com/forums" to search only FTE in the forums, not the entire Internet.
The "-alternator" removes results that would have been returned that have "alternator" in them.
Thanks Chris, guess I'm going to have to start doing that. There's a lot of times I'll be looking for something with the search and can't find it, know it's probably me not the search. But searching Google hardly ever enters my pointed little head. You'd think having been in the computer industry for 20 years I would be able to understand these things a little better but, that was long before the internet.
Using Google works. Here's the wiring I was trying to find.
https://www.ford-trucks.com/user_gal...?photoid=30751
thanks for the help guys, i think im narrowing it down. ive got 3 plugs on the truck, 1 is for the tach i dont have, so that leaves 2. one of the plugs from the truck plugs into the new module, that leaves 1 plug from the truck. there is 1 plug coming from the new harness that plugs into the other side of the module. so that leaves me 1 plug left on the truck side and 4 wires without a plug on the end on the wire harness side. i assume these go together , but since the plug was cut off , im not sure which wire goes where.
So yes, you will have to cut into the engine side of your current harness (the 4 wire plug) and splice these 3 wires.
Or leave your current oil press and water temp wire and just splice the power to the coil. I would do this as it is only one butt splice and does not mess with the temp/press wiring. It will take a while to unwrap the tape to remove them from the current harness.
Jim
