Spindle suggestions
Spindle suggestions
Hey guys, some of you may remember a while back I replaced the wheel bearings, and wheel seal on the front right side of my truck, but could not get the spindle off to do the spindle bearing and seal. My truck also needed brakes and I finally got around to doing the brakes yesterday, but when I took off the front right hub, again it was filled with dirty water. I know the bearings and seal are new, so it must be coming from the spindle. My problem is that I still cannot get the spindle off of the truck! I've removed the six bolts, hit it with PB, the torch, slammed a chisel between the mounting surface with a 3lb hammer and still it will not move.
I have to figure out how to get it off of there so I can replace the bearing and seal! Anyone have some suggestions? Usually I have no trouble with rusty stuff but this one is giving me a heck of a time!
Keyul
Keyul
Thanks for the suggestion! I must not of caught it last time! I'll go rent the 5lb hammer from the store!
I know that I need to get this:
Timken/Spindle Bearing and Seal Kit (SBK1) | 1982 Ford F150 1/2 ton P/U 4WD 6 Cylinders E 4.9L 1BL | AutoZone.com
Why does it say under notes, two required?
ericconn
10-20-2013 10:56 AM
akparker1
02-12-2009 10:23 PM
CBFryman
1983 - 2012 Ranger & B-Series
08-16-2006 04:32 PM
