Looking for rear cab support frame bracket
Hi im new to this site and I own a 94 F150 4x4 and looking for a rear cab support bracket that mounts to the frame of the truck Mine is rotten out and the cab had dropped. I have the new busings for it but need a cab frame bracket but had not luck finding one in good shape. Can anyone point me in the right direction in finding one. Thanks Doug
The rear cab mounts bolt thru a cross member. So you will either need another cross member(riveted in piece), or you can weld in a new piece. Something like this....
Jeffs bronco graveyard sells some
Frame Saver Position #3 Rear Of Cab Set of 2
Yes that for the front cab supports they were fine its the back support I need. About 2 years ago I had replaced the floor pans and the front cab support that welded to the cab left and right side. I will take a pic of the underside and show how bad the crossmember is it needs to be replaced. I will have to air chisel the buck rights off. Doug
66with352
02-28-2018 02:33 PM
600hp48
05-03-2009 02:15 PM
rcav8or
13
04-30-2008 11:35 PM
hoof
01-17-2007 04:03 PM
