Blown speakers
Blown speakers
Anyone else having issues with the stock speakers? Took my truck in the morning after I bought it for the passenger side rear speaker cracking. Yesterday I noticed the passengerside front speaker is cracking. I don't turn my stereo up loud and I can't believe they are this bad????
Factory speakers are crap. Several people have had the same issue, I replaced mine with 4 of these Rockford Fosgate Prime R1682 6"x8" 2-way car speakers at Crutchfield.com
For ~ $140 I got great speakers that sound awesome and will last. It says they are not for the rear but I talked to a tech there and all I had to do was shim them out away from the inner panel. I just cut the screen out of the old speaker and shimmed them out about 1/8" or so. Careful with the bolt behind the rear ( if SCrew) door handle, both sides had the clip you thread that bolt back into fell into the bottom of the door. They are still there... The door closes fine w/o them in there and appears there are no issues w/o them.
Also be careful with the adapter wires, I bent a prong over rendering it useless in the connector so I had to order another set. They are small and fragile so use caution when connecting them.
I had the same problem with my truck, here is my old thread about it here https://www.ford-trucks.com/forums/1...-new-11-a.html
The first time it happened it was a rear speaker, instead of taking it in under warranty I bought an OEM replacement over the counter for roughly $20. Thats how cheap the OEM speakers are. The second time I said forget it and bought four aftermarket Alpine speakers and couldn't be happier.
Ordered the Rockford Fosgates today. Thanks D8. Should be nice when I am done. I already have RF amp and subs. Like I said I don't crank it up loud but it'll be great to have good sounding system. Stockers are junk. (weird cause my SD I kept the stock speakers in it for ten years, and the amp and subs came from that truck)
I'm running stock radio, no amp with my Alpines. To be honest you can turn them up as high as the oem radio can go and there is no distortion. I know people say tuners and exhaust systems are some of the best mods for these trucks. IMO the best thing I did for my truck was replace the terrible oem speakers. Good luck
