Leaking output shaft seal - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 03-31-2012, 10:09 AM
corey3377 corey3377 is offline
corey3377 is starting off with a positive reputation.
Hello,
I have a 96' Ford Econoline with a leaking output shaft seal. I just bought this van a couple of weeks ago so I'm unsure of when this leak started. When I bought it, it was leaking fairly heavily from the oil pan as a few of the bolts were missing. I replaced the bolts and tightened the remaining ones and the oil leak stopped. Now that its nice and clean under there I noticed a small amount of ATF at the bottom of the seal where the slip yoke enters the tailshaft. Mechanic says no problem, we just need to replace the seal. After seal is replaced it leaks worse. He put in a second seal and the leak isn't as bad but still noticeable fluid on seal and a drop or two after shutting off vehicle.
When I bought this vehicle it had very worn leaf springs with one side having a cracked leaf, so I had them replaced. This lifted the rear end approximately 4 inches from how I recieved the van but appears to be about stock height. The drive angles seem fine, but I was curious if this could have something to do with the leak?
Now my mechanic wants to replace the output shaft bushing. When he took off the driveshaft he did seem to think there was a bit too much play in the output shaft as he had another guy at the shop feel it, both said it seemed fine but it they seemed questionable about its movement. Is this the next logical step to stopping my leak? Should something else be addressed, e.g. slip yoke replacement, u-joints, etc???
Thanks
Old 03-04-2013, 09:06 AM
interstategar interstategar is offline
interstategar is starting off with a positive reputation.
leaking trans output shaft seal
I have a 2008 E350 with 438K miles on it mostly hwy driving. I have the same problem with a leaking output shaft leak. One tech says its a worn bushing. I will find out if that's the right diagnosos. The seal was replaced first but it still leaked. U-joints are fine. Tech will also check driveshaft.
Need help with leaking 1356 transfer case mr1 1987 - 1996 F150 & Larger F-Series Trucks 1 09-10-2016 11:38 PM
Ford-O-Matic Slip Yoke Seal Rusty_S Clutch, Transmission, Differential, Axle & Transfer Case 1 09-15-2015 10:54 PM
Tail shaft problem Becauseican1 Clutch, Transmission, Differential, Axle & Transfer Case 0 09-16-2013 01:47 PM
Output shaft bushing now? Ford4Life7.3 1994.5 - 1997 7.3L Power Stroke Diesel 7 08-05-2012 10:15 PM
Transfercase Rear Output Shaft Seal Leak tarzanjane 1997 - 2003 F150 3 06-01-2010 11:50 AM
Tags
2001, 2004, 4x4, f150, ford, leak, minor, output, pump, rear, replace, replacement, seal, shaft, show, small, supercrew, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
