A friends 56' BW Flightning Build Picture- Darkside
My friend who did the build on my 55' and hopefully will do my 56' has just finished his 56' BW cab with a Lightning Engine. Him and his mom are finishing up the interior. It is a beautiful HOMEBUILT truck. Here is the prototype he built to use for reference:
THE CAB HE STARTED WITH
THE ENGINE
03 Lightning
SHEETMETAL PARTS
NOS Running Boards bought new in 1976 by my friends Dad. $44 each
BodyWORK
More to come
THE ENGINE
03 Lightning
SHEETMETAL PARTS
BodyWORK
More to come
Received 4,132 Likes
on
The cab prepaint
THE FINAL PRODUCT. Interior still to be finished
THE BUILD SHEET
Front suspension: 95 Crown Vic Police complete rebuild
Rear suspension: 76 Ford Thunderbird 9" disc brake 3.50:1 ratio w/ custom 31 spline axles positraction, 3/4" sway bar
Modifications to the frame: Completely boxed, front clip welded in, rear spring front hanger raised to top of frame, 2" lowering shackles on rear. Stock rear springs modified with removed leaves.
Brake lines: Stainless w/ stainless braided flex hoses
Wheels: Rocket Booster Front 18x8 - Rear 18x9
Tires: Firestone Firehawk Wide Oval Indy 500 Anniversary Front P245/45R18 Rear P275/40R18
Gas tank: 77-82 Short wheel base Chevy/GMC van.
Motor & Trans: 03 Ford F-150 Lightning 5.4L Supercharged / 4R100
Fuel pumps/sending unit: Stock unit from 03 Lightning custom fit into Chevy tank.
Radiator: New stock replacement - Intercooler: stock 03 Lightning.
Exhaust: 2.5" diameter Stainless custom kit - Mufflers: Flowmaster Hushpower II
Modifications to body: HID headlights & driving lights, rounded corners on the doors, 3" wider rear fenders, exhaust exit through roll pan, LED parking and tail/brake lights, fresh air vents removed, gas fill through bed wood, reverse tilt hood, recess in the firewall moved out to clear heads on motor.
Paint: PPG Concept, Black, Grabber Blue, Performance White, and Sublime Green pinstripe
Steering column: 89 Ford F-150
Seats: 97 Mercury Cougar 30 anniversary
Gauges: Speedhut custom gauges. GPS speedometer
Radio: Clairon head unit. 2 6x9 speakers, 2 4.5" speakers, JL amp, JL 10" subwoofer
Power windows: custom made using stock regulators & parts from 97 cougar windows
Hope you all enjoy the pictures
THE BUILD SHEET
on
Incredible is an under statement, give your friend a well deserved pat on the back for me. He's got one beautiful truck.
Yeah that is the skinner version of me. Since that time a lot of my shirts have gotten smaller it seems! ha ha. We traded some parts for work. I had a Vintage Air evaporator, a new gravel pan, and some front suspension parts. I was there that Saturday as he was laying in the front end. He lives 150 miles away from me. So I wasnt out there often. I was happy for how it turned out and thought other might like to see the build. Maybe get some ideas or something. Shoot might even motivate somebody
