Trans cooler setup for 7.5 460. 93 f350 xlt - Ford Truck Enthusiasts Forums
Old 03-31-2012, 12:54 AM
Leichardti's Avatar
Leichardti Leichardti is offline
Leichardti is starting off with a positive reputation.
93 F350 xlt 4x4 7.5 460
About to replace radiator, water pump, heater core, etc.
Privious owner plugged up the trans cooler ports on the radiator and just mounted a 11"x5-3/4"x1-1/2 trans cooler in front of the condenser assembly.
After I replace radiator should I run the trans fluid through the rad and the trans cooler?
Or any other options?
2 trans coolers and plug up rad?
Thank you for your time.
Old 03-31-2012, 03:13 PM
mustangman mustangman is offline
mustangman is starting off with a positive reputation.
actually running thru the radiator is for colder climates,for warming the trans fluid up, id run without the engines radiator hooked up , just hook up trans up to external fluid cooler,and you can even mount a small electric fan to cooler with remote switch, plus you never have to worry about an internal rupture in radiator mixing antifreeze in ur trans
Old 03-31-2012, 07:19 PM
Leichardti's Avatar
I plan to tow random things up to 9,500 lbs, cold and hot weather, highways and desert.
Will the single small trans cooler be enough? Our should i run one big one or two small ones?
Any recommendation for type of small fan to use?
I haven't added a Trans temp gauge yet, but i know it was running hot last time i was towing.
Old 03-31-2012, 09:18 PM
Lead Head Lead Head is online now
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
The end-tank radiator cooler is not only for cold climates. It will take a large chunk of the heat of the fluid. Without the radiator cooler, your transmission temperature will rocket up during periods of high-load, low/no ground speed since there will not be much air flowing. You should have it setup so the fluid enters the radiator cooler first, then goes through front mount air-oil cooler
Also, are you sure its a cooler the previous owner added? The 460 Trucks came with a front mount cooler that was of a similar size stock. If they completely bypassed the radiator cooler, and are only using the small stock front-mount, your transmission will get hot, real easily.
If you're going to be towing ~10,000 pounds regularly, put the the radiator cooler back in circuit, and put the biggest transmission cooler you can find up front.
Old 04-01-2012, 12:04 PM
Leichardti's Avatar
Thanks for the info. You can tell the previous owner added the cooler because it has aftermarket mounts, zip ties and mounted funny.
When i replace replace radiator, i will run the Trans fluid thru the radiator, then thru the Trans cooler. I will also install a larger one.
Instead of a new large cooler, can i use one of another ford?
Old 04-01-2012, 12:30 PM
The only Ford transmission coolers that are worth putting on these trucks are the 6.0 PowerStroke transmission coolers.
The Factory 460 and 7.3 PSD transmission coolers were way too small
Old 04-02-2012, 06:30 PM
Leichardti's Avatar
Thanks for the info. Ill def upgrade to the 6.0 trans cooler or atleast something similar in size.
1997 f350 7.5 e40d help! hopkins412 1999 to 2016 Super Duty 5 06-28-2016 04:54 PM
Which trans do I have and what trans fluid should I use? fabsroman 6.0L Power Stroke Diesel 17 03-06-2016 10:08 PM
Trans cooler line direction and oil pressure sender location? 93' F350 7.5 Leichardti 1987 - 1996 F150 & Larger F-Series Trucks 2 02-15-2013 05:42 PM
Manual to Auto Trans Swap 95 F150 4.9 oldcoupe42 Clutch, Transmission, Differential, Axle & Transfer Case 1 08-17-2004 04:12 PM
Routing Trans Fluid Through Aux Cooler? 4byford Clutch, Transmission, Differential, Axle & Transfer Case 13 08-11-2004 10:56 PM
Tags
93, aftermarket, check, codes, cooler, f150, f350, ford, location, placement, remote, stock, trans, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
