Charcoal Vapor Canister Delete - Page 2 - Ford Truck Enthusiasts Forums
Old 03-31-2012, 07:59 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
Gas is almost $4 a gallon here. I want every last drop. Even if it is vapor. Speaking of vapor I hope you do something safe with the line. Gas goes BOOM real pretty like.
Old 03-31-2012, 08:48 PM
BrianDguy BrianDguy is offline
BrianDguy is starting off with a positive reputation.
Quote:
Originally Posted by DBGrif91 View Post
If this is just FUEL VAPOR, what exactly is the point of having the canister? Why couldn't the vent line run direct from the tank to the TB? And, further more, if this were the case, why would a purge valve solenoid be necessary? Why couldn't the canister and the purge valve be eliminated altogether and just have a line running straight from the tank to the TB?
The function of the canister is to store vapor to be used by the engine at a later time. The function of the purge solenoid is to allow the engine to use the vapor when told too by the computer. They cannot be bypassed in the manner you speak because engine vacuum would create negative pressure in the tank, and suck raw fuel into the engine.
Old 03-31-2012, 10:06 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
Quote:
Thank you for the simple & direct explanation. Rep point 4 you.
I did not know [or realize, because it seems an obvious problem] that the engine vacuum would cause that to happen.
Old 04-21-2015, 05:18 PM
DrZoom's Avatar
DrZoom DrZoom is offline
DrZoom is starting off with a positive reputation.
Just came across this thread and thought I'd resurrect it and add an interesting perspective. I am a chemist in the rubber industry, and a lot of what we make goes into gaskets. The reason the a lot of car companies are using charcoal canisters is because the acid that is formed when ethanol is burned causes the valve cover gasket and head gasket to harden and crack. My absorbing the vapors, the gaskets are being protected from acidic vapors. The original design may have been for environmental concerns, but it turns out that it is also necessary if you're burning ethanol diluted gas. On the other hand, if you go with FKM or HNBR gaskets, they are not susceptible to acidic hardening.
Old 04-21-2015, 06:55 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Unhappy
So, does this affect condoms too?
My apologies. I just couldn't help myself.
Old 04-21-2015, 07:09 PM
DrZoom's Avatar
Absolutely. Make sure you use modern FKM rubbers when you're jammin' it up the tail pipe. Might also want some heat tape, but that's a different issue.
Old 04-21-2015, 08:51 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The fuel tank has to be vented otherwise the fuel pump won't be able to pull fuel from it, but if that vent is connected directly to the engine it will could pull too much at high vacuum and particularly when the tank is full and pull liquid fuel into the engine and cause a runaway or flooding problem. The charcoal canister and purge valve create a storage system and allow a controlled venting of vapor into the engine when conditions are favorable.. low vacuum.
Let's ignore the fact that eliminating them will trigger codes. I want to know what the practical effect on the engine is [performance or otherwise] if this were to be done. And I want to ignore the codes part because some pre-computer engines also have charcoal canisters, so for my part I am not concerned about the computer aspect of it.
If done properly eliminating the vapor collection system will have no effect on engine operation, but why would you.. this is fuel that will combust and make power so you would be just throwing away some of the value of each tank of gas and negatively affecting gas milage.
Old 04-22-2015, 11:11 AM
rugermack's Avatar
rugermack rugermack is offline
rugermack is gaining momentum as a positive member of FTE.rugermack is gaining momentum as a positive member of FTE.
I paid $56 for my charcoal canister, from rockauto
Old 04-23-2015, 01:38 PM
OklahomaGreyBeard OklahomaGreyBeard is offline
OklahomaGreyBeard is starting off with a positive reputation.
Had a 96 Cherokee that had not one, but two steel tanks implode because the yahoo owner before me bypassed the system and ran the vacuum line direct to the tank return line. Running down the highway at 70 and the thing dies, get out and am looking around under the hood and hear this loud bang and see fuel pouring out from under the back.
Second time around, I removed the entire fuel system on one from the scrapyard just to see what was different and found mine was missing the canister.
Old 12-19-2015, 07:30 PM
jiujitsustudent jiujitsustudent is offline
jiujitsustudent is starting off with a positive reputation.
I have a thought [AND IT SCARES THE HEEBIE JEEBIES OUTTA ME!!!!!], because I have been wondering about this as well.
Depending on the answers I am considering doing this to my 91 F150- and this could be an option for the OP as well.
Man oh man, "line running strait from tank to TB" really???? Man think about raw fuel running into your intake it's gonna be a little Rich. It does serve a purpose Ford spent a **** ton of r&d cash on that fancy black piece of plastic ****!! Mine is stalling and running like **** at a quarter tank and also won't fuel up prope rproperly. Needs to be a nitrous canister not charcoal maybe the truck would grow a set fuxkin gutless gas guzzling *****
Missing Vaccum diagram stinger57 Nevada Chapter 1 12-20-2016 09:26 AM
EVAP system and charcoal canister question alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 13 05-31-2016 06:43 PM
Excessive Vapor Smell from Charcoal Canister - 6.8 V10 TheRedBeast01 Modular V10 (6.8l) 12 06-30-2014 12:09 PM
Does the Charcoal Canister Vent the Gas Tank? AbandonedBronco 1978 - 1996 Big Bronco 16 06-23-2010 02:19 PM
Charcoal line, removed, hook back up?? 78bigunns Fuel Injection, Carburetion & Fuel System 3 11-17-2002 10:00 AM
Tags
1994, 2003, 302, 68, canister, carbon, charcol, delete, f250, ford, light, older, paint, pics, purge, ranger, truck, vapor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
