Proportioning Valve 77 F150 & Weak Brakes
Old 06-26-2012, 06:59 AM
fmtrvt's Avatar
fmtrvt
fmtrvt is offline
I would still change that valve just because.
Even with test vehicles that had fluid changed out regularly, occasionally we would still get a valve that would hang up on us after a few years of service.
Glazing is not a characteristic of light use as frequently thought of, it is from quick high heat events where the organics deep in the friction compound that haven't had the chance to normally carbonize in use vaporize and solidify on the running surface. I.E., if the rear brakes are not working, you have a better chance of glazing front brake pads then when everything is working normally.
  #47
Old 06-27-2012, 12:19 PM
Final Impact's Avatar
Final Impact
Final Impact is offline
Guys, I'm having no luck finding a PN & Part for the F350 combination valve. . .
Anyone have any suppliers up their sleeves?
Thanks!
  #48
Old 12-15-2012, 09:49 PM
fordsrawesome's Avatar
fordsrawesome
fordsrawesome is offline
Just want to say I'm a idiot and thx for the thread it was a life saver ended up replacing ,y entire brake system less the pro valve and it was that dam plunger lol Thx again!!!
  #49
Old 07-09-2014, 04:44 PM
BarneyCarParts's Avatar
BarneyCarParts
BarneyCarParts is offline
I now have brakes!!
Many thanks for this thread!! The Vac Booster plunger was adjusted too short by 1/4 inch on mine too. I adjusted it out and Yahhoo!!! now I can stop the dang thang!!
This Thread saved me many hours of frustration. Many thanks to posters, and Mad Scientist experimenters. You guys are wonderfully appreciated.
Oldsch
11-20-2017 06:54 AM
MarkAnderson
04-01-2017 06:47 PM
51ford fan
01-08-2005 02:35 PM
workin hard
05-27-2003 01:29 PM
tamwill
13
02-01-2001 03:35 PM
Quick Reply: Proportioning Valve 77 F150 & Weak Brakes
