Proportioning Valve 77 F150 & Weak Brakes - Page 2 - Ford Truck Enthusiasts Forums
Old 05-10-2012, 03:48 PM
crazy96863's Avatar
crazy96863 crazy96863 is offline
crazy96863 is gaining momentum as a positive member of FTE.
I will tweak this today and see what happens. Thanks!
Old 05-11-2012, 02:28 AM
crazy96863's Avatar
I checked the plunger thing... Its exactly 1" out as indicated. Purchased another, new master cylinder; got a higher grade than what I had. Bled the hell out of it till no air and then some... Then i did so on the truck.
Still pumping for brakes. I could be wrong but after 4 master cylinders which I have done these same steps with, and the problem remains, it seems to me something else is the issue... How about my plumbing?
The is my proportioning calve... The hoses are routed as such:
Front 45 port - front axle
Forward verticle port - aft master cylinder port/rear port services front brakes
Rear verticle port - forward master cylinder port.
Rear horizontal port - rear brakes
Is this right? Thanks!
Old 05-11-2012, 06:30 AM
OldStyle's Avatar
OldStyle OldStyle is online now
Rusty Roller
OldStyle has a good reputation on FTE.OldStyle has a good reputation on FTE.
Looks like the front lines are wrong. The lower port is missing/plugged.
There should be 5 lines in total.
I know this doesn't exactly show an easy to see diagram but hopefully someone has a better example.
Old 05-11-2012, 07:54 AM
fmtrvt fmtrvt is offline
fmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to all
Normal plumbing routine for a combination valve. Although the designation of front or rear of master will depend on the master cylinder layout as some flip the chambers for front and rear. if you have one of the older cast M/C the larger reservoir chamber is for the front disc brakes.
If you have to "pump up" the brake pedal you have air in the system.
Old 05-11-2012, 08:39 AM
OldStyle's Avatar
Rusty Roller
Thanks for the pic! Reminded me where to look for this one. Only posting it 'cause it names the front outlet locations.... although it probably doesn't matter.
Old 05-11-2012, 11:41 AM
crazy96863's Avatar
This is an educated guess but the fifth port referred to on the bottom front of the valve looks like it is for later TTB trucks where the lines for each front brake run directly to the valve. The plug was installed on this one when I grabbed it from the 79 bronco which had the solid axle.
I took great care to meticulously bleed the current master cylinder and the entire braking system. This is not to say a certain amount of air isnt trapped in there somewhere but IMO its unlikely but I really dont know what else to do; yesterday I took my time and spent several hours to do it as correctly as I know how to.
Let me ask this.... When removing the bleeding hoses from the master cylinder, what is to stop air from getting into the mastercylinder?
Old 05-11-2012, 11:49 AM
OldStyle's Avatar
Rusty Roller
This pictured layout is correct for your 2x4 truck from the factory manual. Separate line for each of the two front brakes.
The weight of the fluid in the master cyl keeps the air out of the master but there is still air at the connection. Thus bleeding the system is needed.
Your front brake lines should have been two separate lines to begin with. Did you change out those when you installed the other components? There is a tee somewhere?
Old 05-11-2012, 12:16 PM
crazy96863's Avatar
I did change the lines as part of this project... There is a single flexible line that is secured to the frame rail which has a t-fitting which is secured to the pumpkin. The lines for each side connects to this.
I bled the system after I connected the master cylinder... I didnt know if there is a tendency for air to get in when braking the connections from some sort of burping effect.
I spent over an hour bleeding the master cylinder. I was even careful to coax some stubborn little bubbles out of the interal ports with a clean pick.
I guess I can take it to a brake shop which would be a waste of money if they are only gonna do something I could other wise do. The problem I have with this is I have some other upgrades to do to the system; before I move on I am simply trying to confirm all my stuff works right.
Old 05-11-2012, 12:33 PM
crazy96863's Avatar
I know it goes against conventional wisdom but I am gonna change out the proportioning valve. I have checked and verified all other components in the system to be working properly although the air in the master cylinder remains a possibility however remote. Hopefully I can find the problem by process of elimination. If this doesnt correct it then it confirms the air hypothesis. Since this one is 30+ years old and a replacement is $15 its a logical, cheap and easy issue to rule out no matter how unlikely. Will keep you posted.
Old 05-11-2012, 01:03 PM
OldStyle's Avatar
Rusty Roller
Quote:
Maybe.... But this is the way the factory designed the braking system for our trucks. Those pics I supplied were from the FACTORY MANUAL. The way you have it is wrong. If it was a good idea then the Ford Designers would have done it that way; which they didn't. Good luck!
I'm not saying it's not a possibility your proportioning valve isn't bad but plugging a line port and your line redesign is.
Quote:
Originally Posted by crazy96863 I did change the lines as part of this project... There is a single flexible line that is secured to the frame rail which has a t-fitting which is secured to the pumpkin. The lines for each side connects to this.
Old 05-11-2012, 01:09 PM
crazy96863's Avatar
I meant I replaced the lines, not the configuration... This is a 4x4 truck... I have seen the same configuration on quite a few solid axle 4x4s... I am sure it is factory. I didnt plug the port; it was like that from the bronco I pulled it from.
Old 05-11-2012, 06:25 PM
bamaf150's Avatar
bamaf150 bamaf150 is offline
bamaf150 is gaining momentum as a positive member of FTE.
Not to hijack but I replaced drums, wheel cylinders, 1 line, shoes, pads and MC and bled the brakes and never touched the prop valve and my brakes are great. Just didnt realize that pulling that pin was required, what does that do? Thanks
  #28
Old 05-11-2012, 07:24 PM
OldStyle's Avatar
Rusty Roller
Quote:
I've never read a real explanation but I think it is to reset the warning light pin and to put the ports in the correct position for bleeding after a partial system failure where the warning light was activated. Just guessing though.....
  #29
Old 05-11-2012, 07:26 PM
crazy96863's Avatar
Bama - what year? I read on a bronco site it will work with H block. Modified the hard lines to fit the prop valve but thinking maybe I should do that...
Just got the prop valve from pnp and heading home to try it out.
Did you have a b1tch of time bleeding your new mc?
  #30
Old 05-11-2012, 08:36 PM
OldStyle's Avatar
Rusty Roller
crazy96863 I owe you an apology! Apparently for 1976 F150 4x4 they used a single line to a block like you described.
Brake Proportioning Valve Delete silar 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 51 03-17-2016 05:03 PM
Need a proportion valve PN tbruz 1973 - 1979 F-100 & Larger F-Series Trucks 10 09-12-2015 02:51 PM
Proportional valve dyoungen 1987 - 1996 F150 & Larger F-Series Trucks 3 06-23-2015 08:35 AM
Bleeding brakes (after replacing all lines) alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-11-2012 01:11 PM
'Factory' location of proportioning valve? alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 11 10-02-2012 10:31 AM
Tags
1977, 77, 97, brake, brakes, f100, f150, ford, poor, problems, proportioning, truck, valve, weak, wot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
