Instrument cluster problems, Please Help
I have an 05 6.0 Crew Cab Lariet. Lately iv been driving down the road and my dash cluster will reset, the chime goes off and the gauges do a sweep like when the key is turned on. It will do it randomly, bumps dont matter, it will do it idling at a light. It was a now and then thing and hadnt done it for about 3 weeks then yesterday it started doing it fairly frequently. This sucks! No loss of power to anything else except radio but it dosent lose the memory. I figured a loose connection to the cluster so i checked them and it was ok. Any ideas?? Maybe a bad cluster.
There was a post with info on cluster repair service with contact info but I can't find it now. Heres a good description of a cluster removal/repair:
https://www.ford-trucks.com/forums/1...t-cluster.html
If the radio is dropping out at the same time it could be related to you ignition switch.
Ed over at FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
Ford Truck Enthusiasts Forums - View Profile: FICMrepair.com
has been doing clusters for a while now. Give them a call and ask.
Ed it top on my list but I like to give options and they are both sponsors.
Ford Truck Enthusiasts Forums - View Profile: CircuitBoardMedics
Sean
Sean
Not sure this helps. My dash gages and radio went dead and my interior lights were on all the time. Everything happened at once. I ended up pulling the dash and instrument panel and installed a remote circuit breaker to turn the interior lights off until I could track down the problem. Very dangerous driving at night with interior lights on. It ended up being a bad "delay" relay.
Ed
Ed
Whammo
2004 - 2008 F150
10-04-2017 03:53 PM
dculen
12-02-2010 10:20 PM
2003, 2006, cluster, excursion, f250, ford, goliath, instrument, instrumental, located, power, powerstroke, problems, ultra, van
