73 360 valve lash settings - Ford Truck Enthusiasts Forums
Old 03-30-2012, 01:29 PM
jnf425 jnf425 is offline
jnf425 is starting off with a positive reputation.
hello! I am hoping someone knows here, im needing the correct gap measurements for the intake and exhaust valves on a 73 f100 with the 360. Ive gotten conflicting info from other places, differing measurements and do both intake and exhaust when hot or do the intake when cold and the exhaust when hot. So, im not sure which is right Appreciate any help, Thanks!!
Old 03-30-2012, 01:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
This will probably add to your conflicting info.
360's have hydraulic lifters and are non-adjustable. The rocker arms have no provision for any kind of adjustment.
Here's a picture of the FE (360/390) rocker arms.
Why are you needing to adjust them?
Old 03-30-2012, 01:49 PM
It was my understanding that you were to bleed the lifters and check the tolerances, and use the different length pushrods available to give you the desired gap.
Old 03-30-2012, 02:01 PM
OldStyle's Avatar
OldStyle OldStyle is online now
Rusty Roller
OldStyle has a good reputation on FTE.OldStyle has a good reputation on FTE.
Collapsed lifter gap: Allowable= 0.119 - 0.219 Desired= 0.144- 0.184
Old 03-30-2012, 02:02 PM
mikeo0o0o0's Avatar
Quote:
Oh, okay. Let me dig out my shop manual and see what it gives in the way of specs.
I'll get back with you.
BTW welcome to FTE.
Old 03-30-2012, 02:03 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
Are you building or modifiing the engine? You shouldn't need to mess with it as part of normal maintenace.
Old 03-30-2012, 02:07 PM
mikeo0o0o0's Avatar
Dang I'm gettin' slow, Oldstyle beat me with how to check.
According to the FACTORY '73 shop manual, the collapsed tappet clearance for the 360/390 is:
Allowable: 0.119"-0.219"
Desired: 0.119"-0.169"
Blown331 is correct though, usually this is only required after some major work, not as part of routine maintenance.
Old 03-30-2012, 02:16 PM
@old style, thank you very much! Exactly what I needed!
@mikeO thanks for the welcome!
@blown 331, got this engine from a guy that had a shop only rebulit the lower end and used all the old valvetrain components, currently have a cold lifter tap so im going to be replacing lifters for sure, and see what else on the teardown
360FE - 390FE questions greentruck72 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 27 10-04-2016 04:47 PM
360 Head Work Question zak8tac FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 05-03-2014 08:01 AM
need hot air intake parts willydad 1973 - 1979 F-100 & Larger F-Series Trucks 8 02-22-2013 04:07 PM
questions about 390 tear down supercabfreak FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 36 11-26-2011 08:07 PM
360 FE with 390 FE crank and rods, is this a good thing or a bad thing? grockin2004 1967 - 1972 F-100 & Larger F-Series Trucks 23 01-22-2010 05:41 PM
Tags
1976, 352, 360, 390, adjust, cold, duty, f150, ford, heavy, lash, setting, tappets, valve, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
