Trouble Code - P0171 & P0174 - Ford Truck Enthusiasts Forums
Old 03-30-2012, 01:05 AM
fortknox81 fortknox81 is offline
fortknox81 is starting off with a positive reputation.
I have a 99 Ford Explorer 4wd 4.0L EFI SOHC 6cyl. Car will start giving out on me when I'm coming to a stop and then idle erratically. As I'm taking off again it will hesitate and surge. Now this ONLY happens in the summer when it is fairly hot and usually after its been driven through out the day and at the hottest point of the day. Just seems like when gets to a certain air temp outside it will act this way. I am getting trouble code P0171 & P0174 or P0172 & P0175 can't remember. I changed the MAF sensor and checked the fuel pressure. I had an auto part salesman tell me they could hear a vacuum leak but only when the engine was revved really quick. I thought maybe the sound they was hearing was air being sucked into the intake manifold. I can't hear a one continuous leak and couldn't find one using propane and hose or carburetor cleaner. The car wasn't acting up when I was trying to find the leak or when the auto part salesman said he could hear it, would that make a difference when trying to find a leak? And am I on the right path looking for a leak or does it sound like something else?
Old 04-28-2012, 04:32 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Vacuum leak.
P0171 code only gibinez 1997 - 2003 F150 2 11-08-2015 08:38 PM
obd code question oldies 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 11-08-2014 01:48 PM
Isolator bolts and misfire cyl. 5? .. (P0420, P1131, P1151, P0171, P0174, P0316, and P0305) Im50fast 3.8 & 4.2L V6 7 11-13-2013 12:31 PM
99 Explorer trouble code P0171 & P0174 fortknox81 Expedition & Navigator 1 03-30-2012 03:23 AM
Vacuum Leak...need help please... los7883 Expedition & Navigator 7 08-20-2011 12:58 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
0174, 2003, 30, 68, code, explorer, find, ford, leak, p0171, p0174, surge, trouble, troubleshooting, v10, v6, vacuum, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
