Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-29-2012, 10:34 PM
chris4735's Avatar
chris4735 chris4735 is offline
Garage is empty, add now
chris4735 is starting off with a positive reputation.
transmission options
can anyone tell me what type of tranny i can use? i have a 400 and am not too sure what to use. i know that a c6will work but what type of bellhousing am i looking for? would one bolted to a 390 work? is there an overdrive tranny that i can use ? help and suggestions would be great.
  #2 (permalink)
Old 03-29-2012, 11:16 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
The 400/351m uses the same bell pattern as the 429/460. A 390 (FE series) will not fit, nor will any other series bell.
A C6 from one of those engines will work. For a OD trans, you are stuck with the E4OD (requires a stand-alone controller, $500) unless you buy an expensive adaptor for an AOD or Chev trans. ($800+/-) And those transmissions need to be beefed to take the power and weight of your combination.
You trying to get better mpg or just reduce rpm on the highway? And what vehicle, gears & tires?
  #3 (permalink)
Old 03-30-2012, 11:39 AM
chris4735's Avatar
Ya that's kind of what I figured with the od trans. I'm just trying to keep revs down on the highway. I'm putting it into a 65 ford with 9 inch rear and 355 gears.
  #4 (permalink)
Old 03-30-2012, 12:07 PM
SoCalExile's Avatar
SoCalExile SoCalExile is offline
1971 Ford F-100
SoCalExile is starting off with a positive reputation.
Any manual transmission options?
  #5 (permalink)
Old 03-30-2012, 12:26 PM
RFAgrasshopper's Avatar
RFAgrasshopper RFAgrasshopper is offline
1927 Ford T
RFAgrasshopper is starting off with a positive reputation.
There are Factory Bell-housing out there for manual transmissions,also a Scatter shield for a 429/460 will work. . There is a nice 3 speed with an O/D that was used in the mid 80's F-150. It is a B&W top loader and the toploader plate has been replaced with the shifter. I had one of these in my street rod project and it's a nice unit. They only run around a$100 to $150 in the junk yard.
  #6 (permalink)
Old 04-01-2012, 09:53 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is starting off with a positive reputation.
e4od tranny option not cheap. Hughes trannys offers a manual shift version of this tranny, not cheap but no computors for the 400. another option is a ZF-42 5speed BUT their are some issues when doing this. if 4wd shift rods need to be clearanced on rear flange and need to run a thicker flywheel. possible to run a 460 flywheel and build a shim to center on back of 400 ford and holes need to be drilled. or have flywheel custom build, not cheap. i have many photos of zf conversion for a 4wd if curious. check albums. the splines on clutch input shaft are only about .250 on shaft at most and a questionable durability situation. can be run but if stout engine will probably be a issue down the road. check photos and drop a message if needing help.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
