Cold Ac when Idle and Hot when driving? Any Ideas - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-29-2012, 09:48 PM
partslady partslady is offline
partslady is starting off with a positive reputation.
08 7.3 F-350 at Idle A/C blows cold air. Start driving and A/C begins to blow warm air. HELP Idle ac cold ,driving crusing warm air.
We have checked amount of freon, check for restriction in orifice tube, cleaned all heat exchangers, and now we re just frustrated because this is just backwards for a normal airflow problem. Has anyone seen this before? The truck is equipped with a big bumper and we thought at first it may be causing the problem
Old 05-14-2014, 11:49 AM
DieselDowdy's Avatar
DieselDowdy DieselDowdy is offline
DieselDowdy is starting off with a positive reputation.
Did you ever find a fix for this. Mine is doing the same thing. And is driving me mad
Old 05-14-2014, 01:31 PM
VindexInjuriae VindexInjuriae is offline
VindexInjuriae is starting off with a positive reputation.
Check your AC clutch engagement, the clutch may be worn enough that it will not hold lockup at higher RPM's. I went through the same problem with my 99, cold when idle & low speed & started blowing hot on highway. AC clutch was worn enough that it couldn't hold when driving. Removed a shim & it works perfect now.
I got the info on the exact procedure for measuring spacing of clutch on a web search, don't remember the site but I can look for it later if y'all don't have luck locating it.
I do remember to test it, all you had to do was drive with AC on & when it started blowing hot, pull over, pop hood & see if clutch is engaged. If not, tap it with a solid object & if it engages, bingo.... you know what's wrong. Just be careful tapping the clutch when the engine is running, don't drop your tappy tool lol
rear a/c doesnt blow cold air jdm5630 2007 - 2014 Expedition & Navigator 7 06-13-2014 12:20 PM
A/C gets warm while at idle LSO1123 1999 - 2003 7.3L Power Stroke Diesel 11 06-28-2013 04:47 PM
2002 navigator rear a/c blows cold then warm jeffrey5679 Expedition & Navigator 2 05-08-2013 10:29 AM
a/c clutch rpbfixit 1999 to 2016 Super Duty 3 07-30-2012 12:20 PM
03 F-250 AC blows warm race39 1999 - 2003 7.3L Power Stroke Diesel 3 03-30-2012 12:59 AM
Tags
2000, ac, air, blows, bronco, cold, colder, conditioner, drive, driving, ford, hot, idle, mountaineer, problems, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
