302 truck engine questions, need advice
#31
#32
I think I found the cobra type 1.7 that came on the 93-95 GT40 heads and these are quite different looking and designed differently from the factory 1.6 rocker on my GT40 head. From what I can tell the cobra 1.7 had roller tips on the rcokers and are made similar in design as todays Comp or Crane roller rockers with exception to the rocker body design and being non adjustable. If this is the case would I be wise to buy the updated adjustable 1.7 rockers since if I did encounter any short comings where if the geomentry was off etc. these could be "adjusted" to correct it in lieu of having to maybe buying longer or shorter pushrods, shims etc. using the cobra style.
Thanks
Thanks
#33
on
Unless the heads or block have been decked it's not likely you will need anything other than the stock pushrods. Here are a couple examples of 1.7 rockers for these engines..
Crane Cams 44746-16 - Crane Energizer Pedestal Mount Roller Rocker Arms - Overview - SummitRacing.com
Ford Racing M-6564-A50 - Ford Racing Pedestal Mount Roller Rocker Arms - Overview - SummitRacing.com
You can pay a bit less than this but you will be getting lower quality. I'm willing to bet adjustable rockers will be more and it's nice to have adjustability but then it's something else that can work lose and cause problems.
#35
Well upon further checking out the ford racing non adjustable rockers
M6529A302 these will not clear the stock valve covers, only the raised 5.0L HO aluminum valve covers. Looks like this is due to the thicker alum. body and the elevation point of the 1.7 roller rockers?
I have not found if the Crane ones state the same. I suppose the original Cobra VC's were taller to accept the rockers? Although from what I seen the original cobra 1.7 roller rockers for the 93-95 looks less beefer than the ford racing ones with the model afforementioned.
The stock steel stamped valve cover's I have off the 98 explorer and the 93 F150 appear to be the same height. Dont know how high or top area of the HO VC is compared to these.
Anyone running either of these steel VC with the Crane or Ford racing pedestal non adjustable roller 1.7 rockers. I sure dont want to order them if they wont fit under my vavle covers.
If I decided to use the stud mount adjustable ones they may present tye same problem.
Ford racing comment
http://www.fordracingpartsdirect.com...m-6564-a50.htm
Crane comment basicly the same
Thanks
Ford racing comment
Thanks
#38
As do I. I've got 1.7 Cobra's under the stock 95 valve covers on my roller 351. The Explorer valve covers are supposedly the same covers the Cobra's used and they're pretty short. It's not the overall height of the covers that's an issue, it's the oil filler baffle inside.
#39
Well that solves that issue. I always get a "fair unbias FTE news report here".
Thanks
BTW I sold the 98 Explorer GT40P heads for $300 (that were never ran, virgin heads) to a young guy who said he wants to get them polish/ported for his 66 tang. He bought the tang recently which was restored right and assumed the 302 that was in it was an older vintage 302 engine. After asking him many questions I found out it was a later roller block with the spider in it. He was thrilled to say the least since he thought he would have to buy the design roller block.
Shortly I will be putting the Explorer 5.0 EFI intakes and other parts that I will not be using. As most of you know I bought the Explorer 5.0 crate motor (never installed) cheap and now seeing the pay back in parts I'm selling
Thanks
#43
Ok with the f150 egine wiring harness using the explorer cam I changed the spark plug/distributor firing order to the 1,3,7 etc.. My question is does the fuel injector wiring harness connectors need to be relocated to match the the specific injector for each cyl. as the spark plug firing order? They fire in batches with the SD system and wondering if the rough idling and sputting when is related to the injectors firing in the batch manner.New spark plugs and wires. Engine under a load running bad also.
Please note the tdc, cam alignment set right on and intial timing running at 10* btc. and all sensors checked fine.
thanks
thanks
Jrock909
02-28-2005 06:53 PM
geokel1014
09-20-2004 08:42 AM
Cloim
04-21-2003 07:14 PM
