lowering 93 f150 - Ford Truck Enthusiasts Forums
lowering 93 f150
Old 03-29-2012, 07:44 PM
f150 3rd gen wrktruk f150 3rd gen wrktruk is offline
f150 3rd gen wrktruk is starting off with a positive reputation.
lowering 93 f150
hi im new to the site bare with me im horrible at spelling and punctuation
ok anyways i have a 93 f150 xlt v8 5.0 and im looking to do a rear flip kit 7-10inches in the rear and 6-11 inches in the front but cant find anything this low. the lowest i can find however is 6 in rear and 4 in front and and am willing to cut fenderwells out if needed
links to sites please and thank you all for the help
Old 03-29-2012, 08:27 PM
882tank's Avatar
882tank 882tank is offline
882tank is starting off with a positive reputation.
First of all most guys on this site such as myself will just keep going if they see a poorly written post. Spelling and punctuation go a long way here. Take the time writing your posts.
Secondly, I believe the lowest you can go without bagging is a 6 inch flip. Even that will require a c-notch. If that isn't low enough I suggest you either leave it alone and enjoy what Ford gave you, or buy a car.
Old 03-29-2012, 11:04 PM
burnout400m burnout400m is offline
burnout400m is starting off with a positive reputation.
I sure know spelling and punctuation go a long way with me. It doesn't have to be perfect but without it posts can be very difficult to read.
As for your question. I don't know much about lowering ( I know more about lifting) but I would think that getting your truck that low is going to require a lot of fab work. You will probably have to cut a section from the frame and add a C-notch and tub the wheel wells and add a channel in the bed to clear the rear axle. I would think to get that low you'd be laying frame on the ground, or be close enough as to make it impractical to drive, so you'll need airbags to raise and lower the truck which means the rear leaf springs will have to go. The front will probably need custom beams, you might be better to change to a twin A-arm front end rather than the stock TTB, like I said I'm no expert. If you can't find a kit that low that's probably because they can't build that much drop into a kit.
Unless you really love your Ford ( I know what that's like) you might be better served to find a truck that has an A-arm independent front end. I think the '67-72 chevy C-10 pickups used A-arm front and coil spring rear so that might reduce the work involved but with that much drop you might have to rip it all out and build from scratch anyway.
Old 03-30-2012, 02:09 PM
Thumper19's Avatar
Thumper19 Thumper19 is offline
Thumper19 is starting off with a positive reputation.
Lowest you can go is 5.5" in the front static with drop i beams and custom made drop coils. Static for the rear you can go as low as you want. Belltech has a 6-7" flip kit with c notch and from there you can weld the flip saddles to the axle and run extra blocks. However the rear will be lower than the front and look fugly like no other.
Old 03-30-2012, 03:42 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Or do as Sportruk did and do a full-on custom:
photo gallery here: Sportruk pictures by Sportruk1 - Photobucket
Leveling Kit Question Tiptonite 1987 - 1996 F150 & Larger F-Series Trucks 6 03-24-2016 08:20 AM
93 F150 sas NotSoSporty98 1987 - 1996 F150 & Larger F-Series Trucks 12 11-12-2015 03:42 PM
narrowed ford 9 inch rear end chad trepanier New Member Introductions 1 10-21-2014 08:51 AM
3 inch drop with rim width. ETOWN55 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 03-17-2014 10:17 PM
'93 F-150 SAS and Front Leaf Swap mkuieck 1987 - 1996 F150 & Larger F-Series Trucks 5 03-19-2012 10:34 PM
Tags
93, conversion, custom, drop, end, f150, flip, front, install, kit, kits, lowering, notch, rear, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
