96 f250 died while driving and wont start
Hey guys first time on this site and i thank you for any information helping me fix my truck.. 96 7.3 f250, it died while driving and would not start back up, I have replaced the CPS, changed out the relays, check all of my fuses, fuel pump is working and gets good fuel pressure, and now i am lost could someone please give me some other inexpensive suggestions?
Thanks,
Beau
Thanks,
Beau
where did you check the fuel pressure? At the fuel rail? Nothing is blocking up the intake is it...know it sounds simple, but got to start out with the basic stuff air and fuel. Is the truck's battery in ok shape, you need enough voltage to get that motor spinning and injectors firing.
It is possible that you missed a fuse problem. Fuse 22 could have blown because the fuel bowl heater shorted out. When it blew, it took out power to the ECU. Common problem - more info in the diesel subforum on this. Short answer - disconnect the fuel bowl heater, replace fuse 22, try again.
Also, while cranking, does the tach bounce around at about 200rpm? If not, you have a bad CPS or bad connection to the CPS. Another possibility is a failed ICP sensor. Disconnect it and if the truck starts, that's bad and needs to be replaced.
Powerstroke_99
29
12-31-2017 08:02 PM
smithj156
07-20-2010 10:42 PM
ajorn
13
12-14-2009 07:59 PM
