96 f250 died while driving and wont start - Ford Truck Enthusiasts Forums
Old 03-29-2012, 07:42 PM
platinumpls87 platinumpls87 is offline
platinumpls87 is starting off with a positive reputation.
Hey guys first time on this site and i thank you for any information helping me fix my truck.. 96 7.3 f250, it died while driving and would not start back up, I have replaced the CPS, changed out the relays, check all of my fuses, fuel pump is working and gets good fuel pressure, and now i am lost could someone please give me some other inexpensive suggestions?
Thanks,
Beau
Old 03-29-2012, 09:19 PM
05victorylly's Avatar
05victorylly 05victorylly is offline
05victorylly is starting off with a positive reputation.
where did you check the fuel pressure? At the fuel rail? Nothing is blocking up the intake is it...know it sounds simple, but got to start out with the basic stuff air and fuel. Is the truck's battery in ok shape, you need enough voltage to get that motor spinning and injectors firing.
Old 03-30-2012, 09:06 AM
Quote:
I check the fuel pressure at the rail from the valve, nothing is blocking the intake and i made sure i charged both of my batterys. I am sure i am getting enough voltage. I have a WTS light and there is no CEL. is it possible that i got the wrong CPS?
Old 03-30-2012, 09:27 AM
Lead Head Lead Head is online now
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
No CEL with key-on, engine-off indicates the computer is not receiving power, or has failed.
Go rent a code reader from autozone and see if you can pull any codes.
Old 03-30-2012, 11:12 AM
Spktyr Spktyr is offline
Spktyr is gaining momentum as a positive member of FTE.Spktyr is gaining momentum as a positive member of FTE.
It is possible that you missed a fuse problem. Fuse 22 could have blown because the fuel bowl heater shorted out. When it blew, it took out power to the ECU. Common problem - more info in the diesel subforum on this. Short answer - disconnect the fuel bowl heater, replace fuse 22, try again.
Also, while cranking, does the tach bounce around at about 200rpm? If not, you have a bad CPS or bad connection to the CPS. Another possibility is a failed ICP sensor. Disconnect it and if the truck starts, that's bad and needs to be replaced.
96 F150 5.0 automatic Tideguy96 Performance & General Engine Building 2 04-12-2016 10:08 PM
Truck looses power and dies on highway railwelder1987 1994.5 - 1997 7.3L Power Stroke Diesel 3 10-03-2015 08:19 AM
2000 F250 7.3 - Truck stalling/dying while driving or parked rustynlaura 1999 - 2003 7.3L Power Stroke Diesel 9 04-26-2011 09:31 PM
96 f350 died while driving won't start Tinker2 1994.5 - 1997 7.3L Power Stroke Diesel 30 04-29-2010 09:54 PM
95 explorer dies while driving but starts after explorerchamp50 Explorer, Sport Trac, Mountaineer & Aviator 2 04-15-2010 04:34 PM
Tags
73, 96, car, check, died, drive, driving, engine, f150, f250, ford, light, start, stopped, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
