Starter problems 94 F150
Looking for some advice. I usually post elsewhere for my '50 but have had a recurring problem with my '94. Turn the key and one click - then nothing. All power gone, dead everywhere. Last time it fried the radio.
I've checked the connection at the battery - clean and tight. I replaced the solenoid. That took care of the problem for about four months then the same problem again.
Any advice would be appreciated, I need to get this running again and don't have the money to send it to the shop. Details - inline 6, original starter. No slow turning or dragging - either it works fine or one click and nothing.
Thanks
Thanks
Many times the cables get corroded under the sheathing. Sometimes the starter works, other times it does not. I would start by thoroughly inspecting the positive and negative cables. Many times I have found the negative cable itself or connector at the battery compromised on these older trucks.
