Intercooler Boot Question
Hey guys....In preparation for at 2500 mile trip pulling our camper next week, I was changing my oil/oil filter and fuel filters and I noticed an oil spot on my intercooler boot heading into the turbo. The only thing I can figure is that there is a hole in the boot and oil is blowing out of it; does that sound feasible? Is changing out the boot something that I should worry about before my trip or is it something that is fine to leave until we return? If I can wait till we return, I'll probably order the parts for Riffraff, which would be the correct item to order --> Riffraff Diesel Performance Parts: - Intercooler Boots
Thanks for the help!!
H2oSprayer,
If I knew I was going to pull that far and had the time to order/change mine, I would change them. You'll definitly know it when it let's go. You'll swear it's a blown tire. You're probably like me and would let it bug you until you change it. If you got the cash, get it done. Be advised that the clamps ARE NOT metric. 7/16" deepwell
If you've got the money I say order 'em and see what Clay will charge you for express shipping. I've got one that looks like that currently...and it hasn't popped. Though I do have the replacements sitting the shop waiting on me.
I'd also go ahead & replace the boot clamps while your there. You could hold on to the old ones for "just in case" on the side of the road.
The correct boot would be the Turbo Outlet boot. This one:
Riffraff Diesel: RDP 6.0L Turbo Outlet Elbow CAC Boot
But I'll tell you, mine was oily on the outside just like that for years and it never blew a hole. It did blow off on me, but that was right after a tech had it off for something else and didn't use a new clamp. I would bet that it will be fine for your trip and you don't need to rush getting one. I always carry an extra clamp, and that came in handy recently.
If I were you, I would wait and buy the whole set from Riffraff when you get back. Get the metal cold side pipe if you don't already have it.
As far as the brake cleaner and the hair spray; I believe the brake cleaner would be to clean the metal pipe of any oil / residue and the hair spray? Is the hair spray used to make the inside lip of the rubber boot tacky?
Is there a specific ft/lbs that the clamps should be torqued to, or is it more of a snug them as tight as I can kind of thing? Again....Thanks for the help guys!!
Thanks for the info guys. I'm still learning the correct terminology of things, to please bear with me. I'm gonna step out an a limb and think that the metal cold side pipe would be where the green arrow as it leads from the air filter, correct? I didn't see a part on Riffaffs site that looked like it. I am still under warranty; if I swap out the cold side pipe to a metal one, could there be any warranty issues down the road?
The hairspray is just a low tech adhesive to help the boot stick. You don't really need it if everything is clean and dry, but it is a helper on the side of the road.
The clamp torque is printed right on the clamp. But to be honest, I don't use a TW. I just collapse the spring and call it a day. Definitely NOT as tight as you can LOL.
'07s were plastic.
Original 03-04 replacement part:
Riffraff Diesel: Driver Side Metal Intercooler CAC Tube Kit
OP: right in front of your oil filter (the bigger black plastic cap), the intake elbow is the metal right angle. The black plastic tube that comes off it and disappears under the air filter is the cold side of the CAC that the part in the link I posted replaces.
Eagleinms
I wouldn't worry about replacing the plastic cold side pipe unless you actually have a problem with it. The boots on the hot side are definitely a good idea though. I bought the RiffRaff boots and like them. The clamps have to be tighter than you think, but not as tight as you can go. I actually had even the RiffRaff boots blow off on me once because I didn't have the clamps tight enough. I checked them with a torque wrench had to go way tighter than I originally had them.
