Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 03-29-2012, 02:07 PM
CKitts CKitts is offline
Garage is empty, add now
CKitts is starting off with a positive reputation.
03' F250 Powerstroke 6.0 - Fuel filter?
I've read quite a bit of these forums over the last few months, and against lots and lots of advice not to, I went ahead and purchased a 6.0.
After 3 weeks, and 3 tanks of gas I picked up my daughter and went to drive out of a parking lot. As I crested the hill the truck stalled out. I immediately tried to turn it over and no luck. It cranked fine, but didn't appear to be getting gas. After several attempts I still didn't smell diesel or hear any change in the engine.
A friend said it could be filters, so I immediately went and replaced both filters. With the crankshaft plug/filter off I turned the key to see if gas would spew. Nothing. After replacing both filters, and putting the plugs back in tight it still wouldn't start.
Last night I read something about checking the fuse for the pump. So first thing this morning, I pulled the fuse, it looked fine so I replaced it. The truck started right up and ran for 5 minutes. After 5 minutes I turned it off, then tried again.. no go. It turns over but sounds like no gas is getting to it.
3 hours later I was told to put 5 gallons of diesel in the tank and put a new fuse into the fuel pump slot. After doing both it started again fine. Ran for 5 minutes then started to chug and shake like it wasn't getting enough gas. I shut it off and tried again. No luck.
The only other thing I have done in the last week was tie a bazooka tube ground into one of the black grounds that feeds into under the truck. (I really dont' think this is the issue but I'm going to move it now that I"m aware it could be the fuel pump ground).
  #2 (permalink)
Old 03-29-2012, 02:52 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Is the fuel pump fuse blowing? If so, you may have a bad fuel pump and it needs to be replaced. Or it may be bad wiring. Check the fuel pump connector for corrosion and signs of heat damage.
I don't see fuel filters blowing the fuse.
Just FYI, Motorcraft or Racor fuel and oil filters only, and make sure you have the OEM filter caps.
__________________
David Chamberlain
2004 F-250 SD, 4x4 FX4, 6.0L PSD
Oregon Chapter Member:
To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 03-29-2012, 02:58 PM
No the fuse for the fuel pump is fine. I replaced it just to remove a variable. Another suggestion was that it could be the Fuel Injection Control Module? The "mechanic" that sold me the truck said it's the fuel pump...
  #4 (permalink)
Old 03-29-2012, 03:03 PM
Getsome68 Getsome68 is offline
Getsome68 is starting off with a positive reputation.
If it was trying to pull too much current it would. Any way to remove a hose from the pump and see if it spits diesel all over?
I'm very new to diesels but there should be some type of nipple in the fuel rail where you can check the pressure with a gauage.
  #5 (permalink)
Old 03-29-2012, 03:12 PM
You said that you replaced the fuse and it ran for awhile. Then you replaced it again and it ran for awhile. This isn't a coincidence.
There is a fuel pressure test port on the upper fuel filter bowl. You probably need to check fuel pressure. If you go down to the 6.0L Diesel forum and read the tech folder, there is a procedure for testing the output voltage of the FICM. The FICM bumps the 12V battery power up to 48V for the injectors. Low FICM voltage is a common problem and will cause some of the issues you have described.
__________________
David Chamberlain
  #6 (permalink)
Old 03-29-2012, 03:43 PM
Perfect, i'll go take a look at those forums.
I pulled the fuse, and put the exact same fuse back in and it started. 3 hours later I pulled the old fuse, and put in a new one and it started. I should have tested without replacing the fuse...
  #7 (permalink)
Old 03-29-2012, 09:26 PM
URDADDY's Avatar
URDADDY URDADDY is offline
2005 Ford F-150
URDADDY is starting off with a positive reputation.
Sure sounds like the FICM to me, do yourself a favor and look around on here for a used one or places that repair them, much cheaper then new. Replaced mine 2 months ago on a 05 F250
  #8 (permalink)
Old 03-29-2012, 09:34 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Power Stroke Diesel forum.
__________________
John
2011 F-350 4x4 Lariat Ultimate, Oxford White / Pale Adobe 6.7L PSD 3.55 ELD / Gone but not forgotten.
2013 Ford Taurus SHO, Tuxedo Black / Black Leather
Moderators, Guidelines, and How They are Enforced / FTE Forum Guidelines
Currently truckless
  #9 (permalink)
Old 03-29-2012, 10:40 PM
zhilton's Avatar
zhilton zhilton is offline
2004 Ford F-250
My Garage
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
Just for the sake of discussion, have you check to see if there's any stored codes? May not be any, but never hurts to check before you start throwing parts at the truck.
Quote:
You'll need a M12x1.5 fitting to thread into the test port of the secondary filter housing. May have to get an adapter since most gauges sold here in the states are 1/8" NPT.
Quote:
FICM Repair.com - Your Source for FICM Repair He's a site sponsor
__________________
FTE Arkansas chapter member
1972 Ranchero GT (351C CobraJet intake)
2001 Explorer XLT 2WD
2004 F250 6.0L 2WD CC "Pavement Princess"
2007 Monaco Starwood SL 31BHD
2012 Focus SEL (Wife's ride)
  #10 (permalink)
Old 03-31-2012, 12:38 AM
Thanks everyone for the advice so far. I've ordered some testing equipment in order to check the above suggestions. However today I thought I'd try to start the truck again..
Started.. let it idle for 15 minutes. Drove forward.. back.. forward... started blowing black smoke then stalled. It posted p0275 Cylinder #5 contribution balance. From the posts I'm seeing on this forum it looks like a bad injector.
I keep hearing/reading stories that if you get a good 6.0 it's rock solid, but if you have any issues.. it's better to get rid of it right away.
Thoughts?
  #11 (permalink)
Old 03-31-2012, 01:17 AM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
The fuel pressure gauge is highly recommended.
Usually if you sell something that isn't running well, you take a hit financially. MIght as well fix it IMO.
Could be that you are sucking air into the fuel system (usually a poorly installed primary fuel filter cap will cause this) or an injector is slowly leaking combustion gasses back into the fuel system. There is a video out on the "bubble test" that will show you if that is happening. I will look for the link.
A scangaugeII will help you troubleshoot. Look for the FICM parameters (MPower, VPower, FICM sync, etc)
__________________
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
  #12 (permalink)
Old 03-31-2012, 01:28 AM
bismic's Avatar
INJECTOR BUBBLE TEST
6.0lit Powerstroke Fuel System Tests - YouTube
Remove the FICM relay and the fuel pump relay
Remove the upper fuel filter cap and the upper fuel filter
Crank engine and check for bubbles with a level of fuel in the filter bowl
If you see bubbles, remove the fuel inlet line to the passenger head (right side) and test by cranking again.
If the bubbles go away, the issue is an injector (or injectors) on the passenger side, if the bubbles remain, then the issue is on the drivers side
Reconnect the fuel line to the passenger head and proceed with removing glow plugs (one at a time) on the appropriate side to isolate the leak
Compression leak into the fuel can come from: Bad copper sealing washer, bad injector cup, insufficient torque on the injector hold down
__________________
Mark
  #13 (permalink)
Old 04-04-2012, 02:13 PM
Thank you everyone for the input. I've passed along most of this information to the guy that sold me the truck and he's having someone try to correct the problem.
Today he drained the fuel tank and said it is really watery, almost as if I filled the tank with regular gas. I told him no I did not, however I guess I "could" have made a mistake but I vividly recall grabbing the diesel pump. Plus I drove the thing for 290 miles before it gave any indication something was wrong. He's now guessing perhaps bad gas?
I'm tempted to pay a tow truck to bring it to Santa Fe to a Ford dealership and have them plug it into their computer. Perhaps I'd save money in the long run by getting it properly diagnosed...
  #14 (permalink)
Old 04-04-2012, 04:05 PM
zhilton's Avatar
2004 Ford F-250
My Garage
Quote:
Unless it smells like gas (the smell would be strong even after it's been mixed with diesel)...it ain't gas. Now it's possible you got some bad fuel if you have been buying it a low volume retailer that has crap in their storage tanks. The WIF (water in fuel) light should have lite up if you had allot of water in there. Figure out if there is something that caused your #5 injector to go south (low fuel pressure, bad o-ring, crappy fuel)...replace the injector and go on with your life. That's how I'd address the problem.
You could do that, and in theory the truck should be fixed properly afterwords. But be forewarned they're going to charge you allot more for labor than you could do it yourself with the knowledge here. I'm not saying don't take it to the dealership...I'd take my truck to a dealership before I took it to several of these 3rd party clowns. But if your mechanically inclined, you can fix the truck yourself and save some money.
__________________
  #15 (permalink)
Old 05-27-2012, 03:29 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
2003 Ford F-250
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
Where in New Mexico are you. Your chapter leader has AutoE, and is willing to do scans for beer
Call me at 505-506-592 three.
__________________
Steve Cox-2003.25 F-250 CC 6.0 FX4 King Ranch
4" Turbo back-
Ranch Hand Cattle Guard-Hollandia sunroof
K40 2000 Radar & Laser 48 Gal fuel tank-Pioneer AVIC-D3,3 amps,12' sub, DVD, TV in headrests
JOIN NEW MEXICO CHAPTER HERE!
Tags
04, 2005, 2012, 60, change, diesel, f250, filter, ford, fuel, motorcraft, oil, powerstroke, presses, pump, recomended
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
