Edelbrock aluminum FE heads - Ford Truck Enthusiasts Forums
Old 03-28-2012, 10:40 PM
rattler12 rattler12 is offline
rattler12 is starting off with a positive reputation.
Any body purchase these? Are they worth the $1500 IYO?
Old 03-29-2012, 04:15 AM
66crawler 66crawler is offline
66crawler is gaining momentum as a positive member of FTE.
Id like to know also, people will say that cast heads will flow just as good but they don't mention that with aluminum you can run higher compression, a bigger cam and still run pump gas. Unless your thinking of going beyond 10:1 comp I'd say stick with some slightly worked iron heads.
Old 03-29-2012, 07:37 AM
DeepRoots DeepRoots is offline
DeepRoots is gaining momentum as a positive member of FTE.DeepRoots is gaining momentum as a positive member of FTE.
I do not own a set of these heads but from what I've been led to believe:
-If you were to need a set of heads, buy a good set of iron heads and have them rebuilt with larger valves, springs, seats, etc etc the costs of the r&r approaches the cost of brand new Edelbrocks.
-If you only want 400-450hp Either type of head is suitable, sadly the iron heads are ending in power whereas the Edelbrocks can be ported for the 450hp+ area.
For myself, I have a set of C1AE heads that I worked over with cj valves, porting, etc etc I will use them while I save up for a set of worked over Edelbrocks for the future. This is a performance application, if I was just looking for cheap stock replacement, I'd be hitting the junkyard or craigslist for usable D2TE heads.
Old 03-29-2012, 10:50 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Good answers, DeepRoots. I concur.
Old 03-29-2012, 12:27 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Unless you worried about casting dates, like mentioned by the time you freshen up a set of steel heads, the Eboks are ready to go.
I run a set on my race car, they aren't too fancy with mild port work(280 int, 220 exh), 2.15 Int and 1.65 Exh(I think? have to check) Dove HD rockers. Very nice heads, I bought mine bare and assembled them for my application. I've had them 12 yrs now.
You can make stock heads work fairly well and if you can do work yourself it will be cheaper. It all depends.
Old 03-29-2012, 01:27 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
My opinion: For the street and mild/moderate HP needs, the stock iron heads are fine. For all out performance/racing use, the Edelbrock (or other aftermarket) aluminum heads start to shine.
It really depends on what you intend to do with the engine, and what your budget is. As the saying goes, speed is a question of money. How fast can you afford to go?
FE engine john jamieson 1961 - 1966 F-100 & Larger F-Series Trucks 3 07-21-2015 08:06 AM
What does FE stand for? ChiefM 1973 - 1979 F-100 & Larger F-Series Trucks 37 07-19-2015 09:13 AM
factory headers riverguideguy FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 07-10-2013 10:49 PM
Dumb question, what does FE stand for? Duke78 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 27 11-30-2008 11:28 PM
390 fe to 410 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 19 03-13-2002 04:24 PM
Tags
239, 28, 390, 406, 64, aluminum, cam, craigslist, edelbrock, fe, ford, heads, sale, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
