Fuel Injection flooding out? - Ford Truck Enthusiasts Forums
Old 03-28-2012, 09:17 PM
packratF350's Avatar
packratF350 packratF350 is offline
packratF350 is starting off with a positive reputation.
Hi all once again!
Got a new problem for you guys to help me figure out. What would make a FI engine act like its flooding out and dying after a short run on the freeway?
Details:
1994 F-350 351W (just overhauled this winter)
has new TPS, ICM(?).
Dual exhaust dumps right before the tires
new filters in tanks, new fuel filter on frame rail
All fuel lines have been opened and blown out from the tank to the engine compartment fitting near firewall.
Fuel pumps hold good pressure when tested.
symptoms:
smells like its running rich most all the time
after a short hiway run @ 70MPH it will stumble and die when returning to surface streets.
fuel smell near engine sometimes, but no obvious puddles or leaks anywhere.
may be related?:
when on a longer hiway run, I can't use the FWD tank for a long period without the engine stumbling and cutting out or popping at times. But I can swap to the rear tank for a bit then run the FWD tank again for a while. driving up hills it seems to be worse, but I'm in the panhandle of TX right now..good grief!
I am having to drive this truck for work long distances. While I dont expect a vast fuel range, it would be nice if I could go a couple hundred miles on 20 gallons of gas lol. Anyone have an idea on this one?
Old 03-30-2012, 08:00 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like you may have two problems:
1. Bad FPR.
2. Bad rear fuel pump (FDM).
Old 03-31-2012, 07:59 PM
I am going to replace the FPR as soon as I can, since you are the second one to suggest that as a cause. Thank you.
Old 04-01-2012, 09:06 PM
Ok I changed the FPR out...no change...I am at a loss as to whats going on here, anyone have another idea?
Old 04-12-2012, 12:24 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.
Excess fuel comes about from;
1. Excess fuel pressure.
2. Faulty fuel regulator, allowing excess pressure or diaphram leaking fuel into the intake.
3. Leaking injectors.
4. Faulty map sensor.
5. Ox sensors not working causing open loop fuel operation.
6. Blocked/restricted return line back to the tank, would raise fuel pressure.
It has to be one or more of these areas.
good luck.
Old 04-26-2012, 08:32 PM
jade79 jade79 is offline
jade79 is gaining momentum as a positive member of FTE.
good luck.
Don't forget a bad coolant temp sensor causing the ECU to think the engine is cold causing a "choke" enriched mixture. The best thing to do is pull the codes. Some local parts stores will do it for free.
Old 02-24-2014, 08:52 PM
07terry 07terry is offline
07terry is starting off with a positive reputation.
what about a 1988 FI 351W flooding and when u give it fuel to clear it up it looks and acts just like the old carb engines put in new cap rotor plugs and wires, temp sensor andair filter thermostat all help is apreciated from a wounded warrior who it will take me a while to check or get someone to check for me
Old 02-24-2014, 08:57 PM
plz help i have a 88 f-150 351W that acts like a carb engine also my gauges on both tanks arent working one shows empty the other over full and i have changed the thermostat, temp sensor temp solenoid plugs wires rotor and cap also air filter i am a wounded warrior so it will take me a while to check the trouble shooting and thx again it floods and clears up when u give it some gas but has gas fumes and rich exhaust
Old 03-07-2014, 10:03 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Check the vacuum line going to the fuel pressure regulator and make sure it has no fuel in it. If it does, then the diaphragm is bad and the regulator needs replaced.
Also make sure that the vacuum line going to the MAP sensor is connected and not dry rotted.
Old 03-09-2014, 04:49 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
The E in EFI stands for electronic so step 1 when diagnosing a problem is pull the codes.
99.5 7.3 falling on its face, no power DentsideCurtis 1999 - 2003 7.3L Power Stroke Diesel 7 11-08-2016 10:36 AM
97 powerstroke surges and missing under load onesr 1994.5 - 1997 7.3L Power Stroke Diesel 28 09-15-2015 05:04 PM
Flooded carburetor Jfitzgerald 1961 - 1966 F-100 & Larger F-Series Trucks 15 10-23-2014 08:07 AM
Fuel System and Exhaust problems. 1986 f150 AWorley 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 11-18-2012 08:34 AM
Another "truck dies when switching tanks" thread... drilling4gold 1987 - 1996 F150 & Larger F-Series Trucks 3 07-16-2012 10:22 PM
Tags
150, 1987, 1997, 42, 60, 88, engine, expedition, f150, f350, flooded, flooding, floods, fooding, ford, fuel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
