95 f350 std cc,
Door lock and window didnt work on the passenger rear door ,replaced the window motor,no problem,but when i started to work on the door lock,i couldnt even find the lock motor or what ever makes it work,it has been like this ever since i have had it,could some one haved removed it.
Need help.
JIM
You guys do realize he is talking about the REAR door on his crew cab right? I am no help since I have never messed with mine, but I am thinking you guys are talking about the front doors since you both have extended cab trucks.
I wouldn't think it would matter for either(I could be wrong)
what I am saying is he has a switch that controls the locks and windows on his DRIVERS door, if the wire is broken going to that, the windows and locks for the other door may not work.
In my case
Drivers window and speaker worked, Passenger speaker and window did not.
It turned out to be the wires going into the DRIVERS door not the passenger. So it could be the same for his back doors.
My truck is a crew cab. I have Already been inside the doors. I'm just saying the lock actuators are fastened to the rear of the door at the bottom. I understood him to say he was trying to locate them
FTE does have a search function...
Tech/Mods/info links used to be a sticky at the top of the main page but SOMEONE didnt like all the stickys and took them all down.
