Try one of the Mr Clean majic erasers or one of the generics. Mr Clean does work, I drive a school bus and we have this issue a lot. They used to paint over or replace the material, I tried the eraser and it worked on my bus! I also recommended it to the shop that does the upholstery, dont know if they did anything however?
Try coloring over the permanent marker with a dry erase marker... and wipe it as you go. It works like a champ on dry erase boards when someone "accidentally" writes with permanent marker on one.
