6.0L Diesel #5 hydrolock - Ford Truck Enthusiasts Forums
Old 03-28-2012, 07:38 PM
den052 den052 is offline
den052 is starting off with a positive reputation.
My 2004 F350 6.0l diesel hydrolocked when cranking on #5 cylinder. Removed glow plug and shot fuel oil out of cylinder so now the engine spins over fine. Question is; does the injector need replacing or maybe just an O ring / copper washer seal problem.
Injector costs between $250-300, O rings and washers are a lot cheaper. I have replaced injectors on other 6.0L engines so I know how to. Can O rings possibly cause this?
Old 03-28-2012, 07:54 PM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Hi den052, I'm going to move this to the 6.0L Powerstroke forum, the folks in there may be better able to answer your question.
Old 03-28-2012, 08:13 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
You need to pull the injector and see if theeres a craked tip or bad oring
If nothing stands out replace injector
Bad enough that it hydrolocked once I wouldnt want it to happen again
Odds are you wont get off that easy doing an Oring
Old 03-28-2012, 11:50 PM
jedlane8870 jedlane8870 is offline
jedlane8870 is starting off with a positive reputation.
Was the copper washer still on the injector ? I have had this issue but it did not start until i replaced the heads, same problem, same cylinder,three different rebuilt injectors last two times new orings and new copper washers were put on just to be safe.
Old 03-29-2012, 12:00 AM
Roasted7's Avatar
Roasted7 Roasted7 is offline
Roasted7 is gaining momentum as a positive member of FTE.
I'd replace everything no matter the cost.
Hope you didn't bend a rod.
Old 03-29-2012, 02:55 AM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD ROBBINthaHOOD is offline
ROBBINthaHOOD has a great reputation on FTE.ROBBINthaHOOD has a great reputation on FTE.ROBBINthaHOOD has a great reputation on FTE.ROBBINthaHOOD has a great reputation on FTE.ROBBINthaHOOD has a great reputation on FTE.
I had a hydrolock issue with my 05 and traced it down to the passenger side via the balloon test. Come to find out #3 injector was missing the brass washer and #1 injector had shot o-rings. Went ahead and replaced all orings and washers on passenger side and its been running like a champ ever since, well like a champ where fuel is concerned. Had the dreaded stc fitting blow out but that wasnt related. I have put probably 6000 miles on the truck since I re-oringed the injectors but everyone doesnt get that lucky. My injectors themselves looked fine other than the orings so I took a chance at just oringing it and knock on wood it fixed my issue. Good luck with yours.
Old 03-29-2012, 03:35 PM
Thanks for the replies. I removed #5 injector, inspected the copper sealing washer and the o rings. Nothing abnormal here. I then tested the injector by hooking up a vacuum guage with a hose that would just slide over the injector tip snugly. If the Injector is good, it will hold vacuum. Wola, it wouldn't hold vacuum and you could see it suck fuel from the fuel ports to the tip. In other words, the injector is open to the fuel passages. So now I have to replace the injector to cure the problem.
Many thanks for the replies.
Old 03-29-2012, 06:54 PM
BLADE35's Avatar
Thats a GREAT IDEA putting Vacum on the tip
Old 03-30-2012, 01:27 PM
Ya, it's way cool. Read it online somewhere and tried it. I had a clear line that fit snugly over the tip. Could see it suck fuel from the ports. Tried it on the new injector and it could hold 22 inches of vacuum. Since I was working on the right bank, I removed the ICP and filled the oil manifold with a pump oiler till oil ran out. Replaced the ICP and cranked the engine. Started right up in about 30 seconds of crank.
I am an old fart, 60 years old. Luckily I took an electronic/electrical class in High School and was involved with computers since the 1980's. This new fuel injection, trucks and cars is right down my alley. Most mechanics my age say "Give me the old carburetor system". I say "Hell no, it's a lot easier to isolate a problem with codes, tests, and etc."
I used to work on the Detroit Diesel's, 2 cycle. They went to electronics before they phased them out of over the road trucks.
Luckily the 6.0L only hydro-locked when cranking. The rod is heavy enough to not bend and the starter doesn't have enough power to bend one I think. It did it on me several times until I could figure out a leaking injector was causing it. I know the concern, but at least with this engine, it did no damage.
Thanks for all the help, Dennis
Cold start blue smoke Stoneburg86 6.0L Power Stroke Diesel 16 12-06-2016 09:52 PM
Catastrophic injector o-ring failure Opraachza 6.0L Power Stroke Diesel 1 03-22-2016 04:41 AM
engine hydrolock valfaro4 1999 to 2016 Super Duty 2 01-29-2015 01:42 PM
Injector update after hydrolock. ROBBINthaHOOD 6.0L Power Stroke Diesel 8 09-08-2011 09:21 AM
Injector O-ring replacement RockinFord 6.0L Power Stroke Diesel 6 12-27-2010 02:10 AM
Tags
2003, 2005, 5, 60, change, coming, diesel, engine, f250, ford, hydrolock, hydrolocked, hydrolocking, injector, powerstroke, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
