2% fuel in oil sample at Blackstone - Ford Truck Enthusiasts Forums
Old 03-28-2012, 03:51 PM
danocross danocross is offline
danocross is starting off with a positive reputation.
I just received my used oil analysis from Blackstone. I have always had stellar UOAs, but this time they noted that at 2% fuel being present, that is borderline problematic. Any comments on this issue are greatly appreciated.
120,000 on the truck, had it since new, 5k oil changes, I did change the fuel filters about a week before the oil change, couldn't do both the same day. I do fuel filter changes every third oil change, 15k interval. No issues since either the oil or fuel filter changes in terms of performance.
I guess I am finding cause and effect but don't want to jump to any conclusions. Also, I am not any kind of mechanic, I do the basic maintenance well and have had pretty good service from this truck. The FICM did go out at 113,000 miles, a Ford dealer replaced it as I was out of town and stuck in the middle of nowhere.
Thanks again for any advice or thoughts on the 2% issue.
Old 03-28-2012, 03:59 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
If you were doing a lot of idling on that oil it's possible that could have contributed to the high percentage. I would just keep an eye on the oil level and look to see what the next analysis says. Might even send a sample in at around 2k miles to see if it's still high.
Old 03-28-2012, 04:48 PM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
Agree with Steve. IIRC, Fords limit is 5%. That is one reason that hours is more accurate for oil changes, however, I also go by 5,000 miles or 6 months whichever comes first.
Old 03-28-2012, 04:52 PM
raptor131's Avatar
raptor131 raptor131 is offline
raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.
I would recommend you buy a new oil dipstick. My old one was dark brown and horrible to discern the oil level, the new one is a lot lighter grey color and will help in determining if you are in fact making oil. Just check more often than usual and make note of the level, if it starts getting higher on the stick then you may have a concern, but I think you should be fine
Old 03-28-2012, 04:56 PM
69cj's Avatar
2% of 15 quarts would only be 9.6 ounces. Don't think you'd see that on the dip stick.
Old 03-28-2012, 05:04 PM
Thanks for the replies. I went back and looked at old UOAs, I did have a 3% reading at 79k miles, so 40,000 miles ago, next reading was less than 1%, so I do have at least a history of a spike.
From poking around, it looks like a leaking injector O ring could cause this?
I had thought about the new dipstick, this will make me go down to the Ford place here, thanks for that heads up. I have had to re-epoxy my old one together twice at the plastic head anyway.
Old 03-28-2012, 05:12 PM
69cj's Avatar
If you keep bouncing between 1 and 3 percent I don't think I'd be concerned. Ford wouldn't be.
Old 03-28-2012, 08:48 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
you got it injector orings Bad
It does it at cold start till truck warms up
I had this issue in 2 weeks I could see the Oil Leval on the dipstick rise 1qt
Truck would run terrible at cold start Idel ruff Missfire wouldnt shift right then all Go away and run fine warmed up couldnt beleive some leaking orings would make it run this Bad But did. Basicaly had the symtoms of a BAD FICM except I was making oil
Be carefull since the fuel system does leak you might suffer from Low Fuel press at cold start if it gets bad over time might start EATING INjectors
You can rering all 8 for less than 1 injector plus it might run better cold mine shure did after I reringed them
Old 03-28-2012, 08:55 PM
Benny, so mine has no symptoms at all, it has been running fine. I was surprised there was any issue at all on the oil report. But I hear ya, easier to do preventative maintenance than face something bigger.
My plan is to watch the dipstick closely and send off another sample in 2k miles. If anything starts to change in terms of driveability, I will be on that too. I am **** about MPG so I will watch that for any changes.
Old 03-28-2012, 09:13 PM
jjaz43 jjaz43 is offline
jjaz43 is starting off with a positive reputation.
Fuel dilution is another good reason for 5k oil change intervals
2 percent by itself is still ok for a 6.0
I would continue to monitor it for now, along with wear metals
For "not being any kind of mechanic" you are way ahead of the curve doing UOA's
Old 03-28-2012, 09:17 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
I wouldn't worry about it at this point. Blackstones method of getting a number is an estimate from the flash point. They do not actually analyze directly for the fuel. Other labs will give you a better number for the fuel dilution parameter. See what it is next time IMO.
Old 03-28-2012, 09:33 PM
Bismic, can you pass along another vendor for oil analysis? Might be good to see a different report, not the same oil sample now but I will give it more miles first.
BTW, my metals readings are very good.
Old 03-28-2012, 09:35 PM
BLADE35's Avatar
From what I have read 2% fuel delution in a 6.0L is Very common
Im with you watch close for awhile Especialy begining next winter when it gets cold and the Orings wear more with more Milage
If you have to go into it for something eles rering them
Mine was making alot of oil I found high on dipstick drained to middle and 2 weeks later it was back up on silver part of dipstick so I was making oil Fast and alot of it plus all the drivability issues cold
also my Bedplate seal was seeping and rear main drip and all of it went away with new Orings Just a couple other things to watch for
Its not to common issue at all but I do figure a few folks have changed a FICM over it and have no Idea bout Orings
Old 03-28-2012, 09:36 PM
bismic's Avatar
OIL ANALYSIS
Blackstone Labs
http://www.dysonanalysis.com/
Butler Machinery Company - Full Service Equipment Dealer
Oil Analysis, Coolant Analysis, Fuel Analysis, Metalworking Fluid Analysis, Fuel Testing, Oil Testing, Coolant Testing — POLARIS Laboratories®
Oil Analyzers, Inc. - Oil Analysis, Oil Testing Services
Aviation Laboratories Contact Us
https://www.herguth.com/testing/prodprot.htm
http://www.mrtlaboratories.com/
I have used MRT, Butler, and Polaris (as well as Blackstone). Blackstone is fine, but I will repeat - their fuel dilution number is not something to get worked up over unless it is continually high (and then I would send it to one of the others I mentioned).
Old 03-28-2012, 09:54 PM
Thanks Mark, that is what I am thinking, just keep it in the back of my mind.
The big thing is the truck is running fine. I appreciate the insight on this, that is the way I learn more everyday on here.
No auto tranny fluid change for first 105K...concern? brychar 6.4L Power Stroke Diesel 56 07-16-2016 12:58 AM
Aftermarket Oil Filter Cap Woes FiveOJester 6.0L Power Stroke Diesel 8 01-17-2016 03:41 PM
Oil Analysis showing Aluminum AVE8R 6.4L Power Stroke Diesel 15 10-29-2015 12:05 PM
Transmission UOA and 4R100 gemniii 1999 to 2016 Super Duty 1 05-07-2015 06:19 PM
School an oil analysis newbie ScaldedDog 1999 - 2003 7.3L Power Stroke Diesel 8 03-07-2011 12:29 PM
Tags
20, 60l, analysis, blackstone, diesel, engine, f250, ford, fuel, idle, oil, percentage, race, sample, samples
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
