Electric Fan Conversion? - Page 5 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #61
Old 05-15-2013, 08:32 AM
BigOl04's Avatar
BigOl04 BigOl04 is offline
BigOl04 is starting off with a positive reputation.
ALL BS ASIDE... I have the 5.4 gas engine and i am running dual 12" 1200 CFM elec fans and have only seen my truck up to 185 tops.. i have an aftermarket temp gauge and they are on a manual switch to activate.. i only saw a 1mpg differance.. (better) now in my opinion.. the AC runs cooler now and so does the truck over stock to me... but all the above are IMPO!!!!! its up to you.. i dont tow alot and used it to help with the drag that the little 5.4 has a hard time dealing with in the heat of summer.. it also made the truck quieter due to not having the horrific sound of a fan blade and clutch spinning around in there.. the fans are also tapped into the power on the ac so if i dont turn the switch on once the ac is activated it will turn then on automatically.. i use this for my auto start in the summer..
  #62
Old 05-15-2013, 10:52 AM
Diamnd1's Avatar
Diamnd1 Diamnd1 is offline
Diamnd1 is gaining momentum as a positive member of FTE.Diamnd1 is gaining momentum as a positive member of FTE.
I have run e fans on my street cars/trucks and my offroad jeeps and they work well. I still have 4 fans that I took off before I sold the vehicle. I have had a fleeting thought of putting some on my V10, but decide against it. The reasoning is, it takes ONE time for the engine to get hot to create issues. A V10 or any super duty engine is very expensive and not the easiest to swap. So, for all the gas I may save in fuel economy will not equal the cost of an engine swap. Therefore, I will keep my mechanical fan on and save the e fan for something less expensive to replace. But that is just my 2 cents worth.
  #63
Old 05-15-2013, 11:05 AM
BigOl04's Avatar
Quote:
yes and thats why i still keep the mechanical fan in the bed in my tote just in case on a long haul it does crap out on me.. i will still have something to put on and cool it..
  #64
Old 12-29-2013, 01:11 AM
AllAboutDaZ AllAboutDaZ is offline
AllAboutDaZ is starting off with a positive reputation.
Any more updates on this e-fan mod?
body lift fan shral billyrayf150 Offroad & 4x4 3 12-24-2015 08:49 PM
Electric Fan Conversion & Water Temp. Question jerryparks 1987 - 1996 F150 & Larger F-Series Trucks 0 08-22-2015 07:46 PM
electric fan conversion ? joe f350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 132 11-24-2012 03:36 PM
Fan Conversion Question MechaNick702 1967 - 1972 F-100 & Larger F-Series Trucks 6 06-23-2012 08:12 PM
Electric cooling fan conversion trsimmons25 1997-2006 Expedition & Navigator 12 09-07-2011 08:56 AM
Tags
alot, camper, cooling, covert, electric, f150, f250, fan, fans, flathead, ford, nova, pulling, running, swap, taurus, trucks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
