You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hey all. Kinda new here, and havn't posted much, but I thought I would share with you all my little project I have started on.
I'm putting a Eaton M112 off a Ford Lightning onto my 4.2L V6 F150. I did a lot of research into this and was looking around on the v6 mustang forums and found that this can be done since we share the same block. The adapter plates made for this setup is for the cobra m112 only, and since our cab forward design doesn't allow much room about the lower intake, the Lightning blower was the obvious choice. The only issue is, I have to build a custom adapter plate.
I will be running 42# injectors, 255lph fuel pump, lightning 90mm MAF housing with the stock sensor, the lightning 90mm throttle body, and some NGK step colder plugs for the supporting mods. I will be tuned by a SCT dealer who specializes in Ford Automatic transmission performance, and I am planning to run 8 to 10 psi of boost until I get forged internals.
very interesting indeed, always watching for ways to get more power out of these engines
__________________
2000 F-150 4.2L V6 2wd..........Daily Driver for now.....
1993 F-250HD 7.3L IDI E4OD 370,000 miles. Straight pipe exhaust. IP turned up 1.5 flats with a Diesel Recon pyro. 0-60 in 11 seconds. Well my rig's a little old,but that don't mean she's slow. There's a flame from her stack, And the smoke's rolling black as coal!
showing signs of a weak bottom end so i'm aborting this project. The whole kit is for sale for $600 OBO if anyone is interested, comes with blower, plenum, air duct, throttle body, maf housing, cone filter, gaskets, and two idler pullies.
