Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 03-28-2012, 10:18 AM
USArmyTaterness's Avatar
USArmyTaterness USArmyTaterness is offline
2000 Ford Expedition
USArmyTaterness has much to be proud ofUSArmyTaterness has much to be proud ofUSArmyTaterness has much to be proud ofUSArmyTaterness has much to be proud ofUSArmyTaterness has much to be proud ofUSArmyTaterness has much to be proud ofUSArmyTaterness has much to be proud ofUSArmyTaterness has much to be proud ofUSArmyTaterness has much to be proud ofUSArmyTaterness has much to be proud of
Dewain Zeglin Fluffythund3r
Strange humming
Ok so just picked up my expedition today from the PO running good I came out of work today and heard a humming wasn't sure what it was thought maybe the fridges from the store in front of me started up drove home with no problems.
Get home and shut of the vehicle pull the key out of the ignition and the humming is there I pop the hood and what I am assuming is the fuel pump is still going like crazy.
Just to make sure what I am talking about it is a black box underneath the air intake on the drivers side just below the coolant overflow tank. Has steel lines running in and out of it.
So if it is the fuel pump WTF makes it do this is it normal ( I don't think so never heard a car do it before) or what could be the cause?
__________________
Warning: May not be held responsible for anything said on duty, or that makes your wife mad.
http://www.ford-trucks.com/forums/11...l#post11721058
  #2 (permalink)
Old 03-28-2012, 10:19 AM
Since I wasn't sure what it was I disconnected the battery for the time being.
__________________
  #3 (permalink)
Old 03-28-2012, 10:22 AM
Triple post FTW forgot to mention
2000 Expedition 2WD XLT 4.6L
__________________
  #4 (permalink)
Old 03-28-2012, 11:49 AM
Found the problem so we are all good now and for anyone who might have this problem in the future.
The box below the intake is the ABS motor runs your brakes for the system. Just the ABS the temporary fix will not affect your braking in any other manner.
Remove power i.e disconnect battery.
Remove the fuse 102
Return power connections
If the noise returns it means that the ABS ECU has failed causing the circuit to run in the open position I am sure this is supposed to be a safety thing. However it causes the ABS motor to run non-stop even with the key power off and the key out of the ignition.
Replace the ABS ECU and replace fuse 102 problem solved.
Thanks for your help yall I know there were no replies but I searched around to get any ideas
__________________
Tags
2003, 360, air, expediiton, expedition, f250, ford, funny, hum, humm, humming, intake, making, radio, stop
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
