How hard is it to replace a clutch? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-28-2012, 09:20 AM
19fifty4 19fifty4 is offline
19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of
I think the time is near for a new clutch in my 98 Ranger, 2wd/ 5 spd. How tough of a job is this? I've changed the one in my 66 Mustang years ago but things were less complicated then. What kind of time and expense am I looking at? Thanks for the feedback.
Old 03-28-2012, 09:52 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
The basic proceedure isn't that much different, aside from the bellhousing being integral to the trans. The throwout bearing sits on the internal slave cyl, which is a reccomended item to replace while you have the trans down.
The 2 biggest "tricks" is getting the shifter handle off, and seperating the hydrualic line for the slave cyl.
Old 03-28-2012, 12:32 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
reall its not bad IF you have all the tools and stuff. You didnt specify 4 cyl or v6 so there is a difference. On the v6 you will need to have a 24inch extension to get at the upper bell housing bolts, and also a long one for the exhaust header bolts. If you have 4 jack stands its easy, I have some 16-18 long studs I use to slide the trans on for removal install, makes it easier by yourself.
I would also recommend that you R&R the master cyl while doing the job as either it will fail later or cause the slave to go out again sooner.
Old 03-28-2012, 09:12 PM
It's a 4 cylinder. Decisions, Decisions.
clutch pedal spring AJHEATING 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-31-2016 11:32 AM
AC clutch disappeared dmueller71 1999 - 2003 7.3L Power Stroke Diesel 4 09-18-2015 11:21 PM
Valair clutch question Bird Hunter 1994.5 - 1997 7.3L Power Stroke Diesel 1 04-23-2013 07:52 PM
How to bleed master/slave clutch cylinders 89nolaf250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 01-31-2010 01:37 PM
how to bleed the clutch on my 1989 f-150 JustinGustafson 1987 - 1996 F150 & Larger F-Series Trucks 2 11-16-2006 01:42 PM
Tags
1997, 98, ac, b2300, change, clutch, difficult, easy, ford, fors, hard, hydrualic, mazda, problems, ranger, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
