GM ignition switch in my Monaco RV! Help me get rid of it please! - Ford Truck Enthusiasts Forums
Old 03-28-2012, 02:01 AM
vacuumbed vacuumbed is offline
vacuumbed is starting off with a positive reputation.
I am buying a 1996 Monaco Executive class A diesel pusher RV. Even though this RV is not a GM, the stupid thing has a GM ignition switch!
I'm a Ford man. I like a Ford ignition key in my hand. Makes me feel good.
I need to get a Ford lock cylinder and ignition switch in this thing and toss the GM one in the garbage where it belongs haha.
So this is a dash mounted ignition switch. I don't think Ford has used them in years. The latest one that I can think of is the 1967-1979 Ford trucks and pre-1969 Ford cars. I think the late model Ford stripped chassis trucks use a column mounted switch.
Does anyone have any ideas of what Ford ignition switch and lock cylinder would be best for this?
Old 03-28-2012, 07:11 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
I'm betting Standard Motor Parts (SMP) would have something perfectly suited for you; maybe Dorman too?
Your biggest issues will be how the new switch fits through the dash board hole and its connections too--both easily overcome if you're creative enough.
Old 03-28-2012, 03:04 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Just get a new GM switch. It probably won't be made by GM, it will be made by a aftermarket vendor who gets them made in China, the same place that makes the replacement Ford switches.
Old 05-03-2012, 08:26 PM
I pulled the GM ignition switch and it turns out to be the same one used on 67-72 Chevrolet trucks. Lovely
I am going to install a Motorcraft SW-944 ignition switch and a SW-814 lock cylinder and keys. These were used in all Ford trucks up to about 1977.
I don't care what it takes to make it fit, I willl make it fit.
Old 05-04-2012, 03:58 PM
I just for the Motorcraft SW-944 ignition switch and a SW-814 lock cylinder and keys and the lock cylinder does not fit the ignition switch. Hmmm I wonder if one of those parts are wrong?
Keys, Locks, & Ignitions Moe Craig 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 01-07-2016 09:14 PM
GM Steering Column in my Ford - But,, its not HunterSThompson General Automotive Discussion 4 08-21-2015 11:47 PM
Monaco Motorhome - need U-joint help 05coach Large Truck 1 05-15-2015 06:05 PM
Rewired 67...won't turn off??? 67F250RET 1967 - 1972 F-100 & Larger F-Series Trucks 2 02-04-2013 06:23 AM
Well I did the gm module duraspark II distributor, tfi coil conversion (long post) jwtaylor Performance & General Engine Building 43 11-23-2004 09:30 AM
Tags
1979, 1999, buy, chassis, dash, diesel, ford, forum, gm, ignition, key, monaco, monoco, rv, switch, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
