Ford 6.7 diesel m.p.g.
Well, actually this is backwards. Gasoline prices are finally getting back up to the diesel range. Diesel never went down much when the gas finally started dropping. But since the prices have started rising again, at least diesel hasn't risen in conjunction with gas. It's only gone up a little, while gas has gone up nearly $1.00 a gallon. It's almost caught up to diesel.
Well, that's not so far off. I'm over in the Houston area. I was at Canyon Lake and Kyle area just a couple of weeks ago and got diesel for $3.93. So that's up in just a couple of weeks. Here I get it currently for $3.93. Regular unleaded was sitting at $3.87. So it's only 6 cents difference here.
Regardless of all that, it's just too dang much. And it shouldn't be.
F250 6.7 desiel MPG problems
First I want to say I love this truck and the 6.7 desiel. That desiel just doesn't say no. However for the first 8,000 miles I averaged 18 MPG around town and 20 -21 MPG on the Highway. Then all of a sudden the mileage dropped to 15MPG for both local and highway driving. I have been to two different Ford dealers and both told me they couldn't find anything wrong and Ford doesn't guarntee MPG on these trucks. Basically
to bad you are on your own. When I ask others that have the same truck they are getting 20 -22 MPG highway. Something must have broken and the diagnostics just are not good enough to figure it out. I have checked the mileage out the old fashsion way and with the computer. They both agree. Does anyone have any Ideas or where to go from here ?
I was getting 18 local and 20 MPG Then all of sudden it dropped to 15 MPG for both local and highway. I have been to two Ford dealers and neither could find anything wrong. They told me Ford doesn't guarntee MPG on these trucks and they couldn't do anything. Others seem to be getting 20 - 22 MPG. It would seem that there is a design fault somewhere in the diagnostics. Does anybody have any ideas of where to go from here ?
I have an idea for where to go.... 6.7L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Post your question down there and those guys can give you their input.
I have the 2012 F-350 dually crew cab and I notice when I passed 5000 miles on the odometer it jumped past 18 mpg and then it went back to 15 mpg. I figuered I was getting upper 15's because I have a dually 4x4 crew cab the heaviest possible but sometimes the truck get above 17 mpg consistently driving the same exact way and route with no head wind. Now I get 15.7 to 16.4 mpg and mainly highway. There is definatly somethjing wrong because how can it give me 18+ mpg and then for no reason drop to 15 or even 14 mpg driving the exact same way and route? All the other cars I have had and even previous diesels have not varied like this one has and since the sticker on it doesn not quote a MPG there is nothing you can do and have to accept it. I am currently looking for a truck with the 5.9L Cummins for my brother-in-law because those things consistantly gave 22 to 24 mpg and if you don't neet to tow 24,000+ pounds than you don't need one of these new trucks with all the emission control and backed up exhaust. I always use additave to lower the cetene level because these engines were made to European diesel standards and they have much cleaner fuel overthere. I was told that is why Ford makes the fuel diesel addative. I also just changed to oil for the first time and put Rotella synthetic 5w40 and the next time I am using Mobil 1 diesel truck synthetic oil. I was told by another guy on this forum that after 5000 miles he noticed a jump in MPG (like I did) and then again at 11,000 but not as much. I know it is not the computer because I calculated the MPG the old fashion way to and it is right on. I was told that it is the computer not use to your driving habits and when it finally resets itself after a while it will increase your MPG. Since I just turned 6,000 on my odometer I guess I have to wait to see what happens when it is finally broken in. I was told that could take up to 18,000 to 20,000 miles for this engine to achieve full break in status and operate at the highest efficiency. Keep me posted if you come across any additional information on your MPG problem.
429Martian, I will let you know what I find. I just contacted Ford about the problem. I am pretty sure something broken. Either software or hardware I am not sure. It was real nice when I was getting 20 MPG. Yes I checked it the old fashion way so I'm pretty sure it was accurate. I also noticed that it doesn't matter if I am driving local or highway I still get 15 - 15.4 MPG. I am thinking that the truck is running richand at speed it doesn't lean out. If we all hang together we will get Ford to fix the problem. Your right about the Cummins they get great mileage !
Joe
Joe
Joe
Joe
Joe
Joe
Frank
#29
Yes it is very possible that something went wrong with the cleaning system. However it is not giving any codes and two Ford dealers couldn't find anything. My guess is what ever went wrong the diagnostics on this new engine aren't good enough to pick it out and the dealers just give up without a code to shoot down. I think this is the difference bewteen Japanese car dealers and US. You spend close to $60K on a Japanese car and there ios a problem they have a team of techs and Engineers looking to see why there isn't a code. The US car dealer tells you we don't guarntee mileage there is nothing wrong even if others are getting 18 / 20 MPG .
Thanks for responding.
#30
i am not going to hit the OP with some crazy wide range of mileage. this truck, my brothers rig, averages 15-16 mixed, 12-13 towing light, like 6K. its the truck in the pic below before the lift and 36s. it may show 20 if reset once your velocity has stabilized on the hwy, but, you need to zero it when before you leave your driveway to get closer to actual.
