1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
5.4 Triton Expedition Rebuild/Replace Advice
Old 03-27-2012, 06:41 PM
skyysipper's Avatar
skyysipper
skyysipper is offline
Just acquired a 1999 Expedition Eddie Bauer, 5.4 Triton with 16x,xxx miles. Removed the engine and a small amount of metal shavings are in the oil pan, so a bearing has spun? It wasn't running and was partially dismantled when i got it.
Bearing in mind i'm on a limited budget, any thoughts on the following?
1) remove the rod caps and then the crankshaft, inspect for any grooves etc, and if none to speak of just replace bearings and throw the engine back in?
2) just find a used engine and take a bit of a risk and just throw it in?
Old 03-27-2012, 07:36 PM
alloro's Avatar
alloro
alloro is offline
Received 4,174 Likes on 2,419 Posts
Well since you're on a budget I'd go with the least expensive route. Labor is free, it's the parts you have to figure for.
Old 03-27-2012, 11:59 PM
Ironhand03's Avatar
Ironhand03
Ironhand03 is offline
Once you find metal shavings in the oil pan that means they are everywhere in your engine. That means you must remove and clean everything. The lash adjusters have small oil holes in them and if oil doesn't get inside the lash adjuster the roller follower wont follow the cam profile correctly and can result in a dead valve.
Depending on weather a rod or crank bearing spun will be the big part in cost. Usually the crank can be saved if it was a rod bearing and if it was caught early. If it was a crank bearing then you might as well throw it in the trash and get a new crank. A new crank is typically cheaper then all the labor to repair your existing crank.
Where do you live OP?
Old 03-28-2012, 04:01 PM
alloro's Avatar
alloro
alloro is offline
That could be true but it's not a given. With a bearing the metal is pushed out and into the pan. From there the metal has to be able to get passed both the oil tube pickup screen and the oil filter before it can get to any other part of the engine. The one exception is the oil pump since the oil passes through it before the oil filter. He could very well get away with replacing the bearing and oil pump, cleaning the pickup screen, and installing a new oil filter. But like you've pointed out, the metal could've reached other parts of the engine and I'm not there to see for myself.
It couldn't hurt to pull a valve cover and inspect the oil puddles for signs of metal particles. I've used a bright light to look for flashy particles.
shaffecv
1999 to 2016 Super Duty
23
03-23-2018 06:57 PM
zloomis
03-17-2016 08:55 PM
xcrmk
Modular V8 (4.6L, 5.4L)
03-25-2015 07:23 PM
79FordBlake
08-04-2010 10:56 AM
my93
03-25-2009 02:40 AM
Quick Reply: 5.4 Triton Expedition Rebuild/Replace Advice
