Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 03-27-2012, 06:41 PM
skyysipper skyysipper is offline
Garage is empty, add now
skyysipper is starting off with a positive reputation.
5.4 Triton Expedition Rebuild/Replace Advice
Just acquired a 1999 Expedition Eddie Bauer, 5.4 Triton with 16x,xxx miles. Removed the engine and a small amount of metal shavings are in the oil pan, so a bearing has spun? It wasn't running and was partially dismantled when i got it.
Bearing in mind i'm on a limited budget, any thoughts on the following?
1) remove the rod caps and then the crankshaft, inspect for any grooves etc, and if none to speak of just replace bearings and throw the engine back in?
2) just find a used engine and take a bit of a risk and just throw it in?
  #2 (permalink)
Old 03-27-2012, 07:36 PM
alloro alloro is offline
alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.
Well since you're on a budget I'd go with the least expensive route. Labor is free, it's the parts you have to figure for.
__________________
To thank someone, click the left red "Add to Reputation" button
right of the word "permalink" top right of the poster's message.
  #3 (permalink)
Old 03-27-2012, 11:59 PM
Ironhand03's Avatar
Ironhand03 Ironhand03 is offline
2003 Ford Mustang Cobra
My Garage
Ironhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputation
Ironhand03
Once you find metal shavings in the oil pan that means they are everywhere in your engine. That means you must remove and clean everything. The lash adjusters have small oil holes in them and if oil doesn't get inside the lash adjuster the roller follower wont follow the cam profile correctly and can result in a dead valve.
Depending on weather a rod or crank bearing spun will be the big part in cost. Usually the crank can be saved if it was a rod bearing and if it was caught early. If it was a crank bearing then you might as well throw it in the trash and get a new crank. A new crank is typically cheaper then all the labor to repair your existing crank.
Where do you live OP?
__________________
Cory
FTE Wisconsin Chapter Leader
*Click Here To Join*
98 Expedition. 4x4, DD
03 DSG SVT Cobra(Aiming For 1,000rwhp, Blower Only)
2012 Ford Fusion. SEL AWD, Fully Loaded.
  #4 (permalink)
Old 03-28-2012, 04:01 PM
Quote:
That could be true but it's not a given. With a bearing the metal is pushed out and into the pan. From there the metal has to be able to get passed both the oil tube pickup screen and the oil filter before it can get to any other part of the engine. The one exception is the oil pump since the oil passes through it before the oil filter. He could very well get away with replacing the bearing and oil pump, cleaning the pickup screen, and installing a new oil filter. But like you've pointed out, the metal could've reached other parts of the engine and I'm not there to see for myself.
It couldn't hurt to pull a valve cover and inspect the oil puddles for signs of metal particles. I've used a bright light to look for flashy particles.
__________________
Tags
54, 99, authorized, bearing, bearings, cam, change, engine, expediton, fix, ford, navigator, rebuilding, rod, thrown, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
