Pedal pin
John,
A friendly suggestion: Put the year and model of your truck in your profile and even in your signature, as well as your location so people don't have to search or ask for that info each time. Next when you start a topic and/or ask a question put enough information in the title to quickly catch the attention of those most likely able to help you.
"Pedal pin" could mean anything, and doesn't even let us know it a a question.
"Looking for the pedal pivot locking pin for my 49 F1" would get you quick correct answer.
It's nothing special... Pretty sure True Value and Ace Hardware sell clevis pins that size. McMaster, Grainger, and Fastenal also have them.
1/4" x 1 1/2" Stainless Steel Clevis Pins - 5 Pieces
DrillSpot 0156730 1/4" x 1-1/2" Zinc Finish Clevis Pin
McMaster-Carr Clevis Pins
Clevis Pin, Zinc, 0.250x1 1/2 L, Pk10 - Clevis Pins - Pins - 2XAR2 : Grainger Industrial Supply
pin
I used a mic on the part and its over size by 5 thousands. When I ground the head off it still had to be pressed out. I guess a 1/4 pin would work peaned over. I also was thinking of a spring pin but I asked the question to be able to put it back together like they did at the factory.
Ross, thanks for the picture. I found the same in my catalog this morning.
hello113
05-18-2019 12:08 AM
53OlderThanMe
11-17-2013 12:49 AM
soooop
08-16-2010 09:17 AM
