Towing without monitoring EGT's ?
I am going to be going on a trip to West Virginia this spring towing a small trailer that weighs approx. 6,000 to 7,000 lbs. I currently am not monitoring EGT's. I have an Insight for gauges but have not Installed an EGT probe because I'm leary of drilling my manifold if I don't have to. My truck is bone stock so do ya'll think I need to worry about EGT's ? I haven't bothered with it because I only tow occasionally and it has all been flat road up until now. I have heard that a stock truck won't get hot enought to worry about but then again others say it can. Thanks in advance!!
No, it is not necessary. If you get a tuner to get more power while towing then I would say it is required. That weight is nothing to cause high egt's. but I saw top egt's with my 11k tt top out around 1300. But once you let off a little it would drop back to 1000 -1100 fairly quickly. My truck is not tuned btw. Don't be scared to drill your manifold. Drill it dry and use a vacuum to suck out the shavings, it won't hurt anything. The only way i can think of for them to get too high is from a bad injector on a stock truck. What type of grades are we talking here on this trip? And how long?
I pull my 31" fifth wheel up the eastern Siearras with out monitoring egt's. Totally stock truck. I do monitor ect/eot and tranny temps. If you pull over after a long pull just let her idle for 4 or 5 minutes before shutting it down. Usually by the time you get off the highway and find a place to park she has already cooled down sufficiently.
The pyro
This is a must if you pull heavy even if you do not, need for cool down 350*-360* before you turn the key off.
After drilling it out i used a magnet with a paper clip with a L shape on the end clip taped to the magnet run in the hole to remove any steel then tap the hole going only half way with the tap so you do not over size the hole, do not use grease. (the steel is soft so be carefull) Take is slow you can do it.
3-Gauge Install Pictures
pop
pop
By the 3 in one gauge set from Glow Shift
My gauge set from glow shift is now even on sale. My main arrow gauge is exhaust gas temp. The secondary digitals are radiator outflow temp and boost in inches. The package is neat clean and out of the way. One gauge 3 functions. Also do not worry about drilling the exhaust then tapping for the pyro sensor. Glow shift sold me a hose clamp type devise. One small 1/8 inch hole in the pipe, then the tip of the sensor goes in and simply threads into a spot welded on to the clamp. They have an unlimited combinations of this triple gauge. Choose temp egt vacuum oil temp whatever you want they set it up and ship you everything you need. Ordered the single pillar pod mount in one of 3 colors, and the neat thing about that is I got to keep the factory grab handle to haul my 60 year old butt into the cab. Bye the way with a 6.0 think also about an ehaust gas delete and do not run without a coolant filter system. Spend 2000 before you lose 8000 bucks.
The pyro
pop
pop
mtgrzlyman
08-20-2006 01:43 AM
