Need York Compressor flange
Posted in the 'Cooling and Heat' section and got no hits. I need some help.
Got the airconditioner out of a 77 F100. Another guy was restoring it, took out the stock unit for an aftermarket unit. I bought the compressor, evaporator, and condensor for $100. They are all in pretty good shape EXCEPT:
The York 210 compressor is missing the flange on the suction side. This is not my unit, but this is one with the flange need.
I've scoured the net and been to kilbystore.com. Kilby has a flange but it has a 1/2" NPT end for use as an onboard air compressor...won't work for me.
Does anybody have a source for these guys??? I can't find one anywhere. Went through an entire JY and found nothing. I really need some help here.
Thanks.
Thanks.
I think your looking for the backseat valve ?
Scroll down and see if this is what you want..................................
Mustangs Unlimited - The Premier Source for Mustang, Shelby and Cougar Parts and Accessories
You can get some of these if you are converting to R134 and it doesn't matter if it's not original.
Tube-O Suction & Discharge Fittings with R-134a Port - Compressor Fittings
EDIT: sorry I see now in the pic the fittings you need attach differently, so those won't work for you.
Did some research. You have the flange style fittings, not the rotolok fittings normally found on Fords.
According to the York service manual, if you're converting to R134a you can use these fittings.
P/N 022-21933
Flange mount style w/ O-ring hose connection, 1/2" (#8) hose, 3/4"-16 UNC thread, w/R134a charge port
P/N 022-21932
Same as above, 5/8" (#10) hose, 7/8"-14 UNC thread w/ R134a charge port
These are York part numbers, the suction side will be the #10 fitting
P/N 022-21933
P/N 022-21932
Thanks. I found a flange that converts it to tube o-ring at Napaonline. Ordered a set and then ordered a hose kit from Nostalgic.
Cut and fit the cables, mark them, and ship them back to Nostalgic and they'll crimp them for free, all I do is pay shipping.
Converting to Tube O-ring is the better way to go. Thanks for the help.
NAPA AUTO PARTS
Universal R-134a Hose Kit with Drier - AC Hose Kits
NAPA AUTO PARTS
parr4
07-19-2010 10:39 AM
